Delta Fan, does third wire (lock signal) need to be connected to run?
Rotor lock or tachometer signal outputs do not need to be used in order for a fan to spin and move air. Most fans with speed control inputs are also configured to run at maximum speed if the control wire is unconnected, so those generally do not require connection either.
Further information on related topics can be found here.
