Details
------Question for 141-0000-930 Please Put your question below------
HI , does this come with the /16" open end spanner adaptor ? What about calibration, I need to calibrate at 5lb" ?
The data sheet tells me this is a non-adjustable (so no user re-calibration) 5 inch-pound, +/-0.2 inch-pound, torque wrench with the 0.315"(5/16) end permanently attached.
Since it is not mentioned in the sheet, I assume it does not come supplied with a calibration certificate (most electronics tools & instruments do not).
Hi Paul,
Appreciate your sharing. Points noted.
Thank You n have a good one.
