Hirose Electric Connectors
DF13A-20DP-1.25V(25) obsolete part and DF13EA-20DP-1.25V(35) replacement part
What is DF13A vs DF13EA?
What is (25) vs (35) designation?
Hello Greg,
Welcome to the Digi-Key Tech Forum.
In my research for the answer to your questions I found that EA is a insulation material change as per the snip below.
Here are the links to the documentations containing the above information.
430-15086.pdf (digikey.com)
430-15086_E.pdf (digikey.com)
Hope that helps.
That’s exactly what I needed. Thanks.
