Diameter of Pogopin
------Question for 10114 Please Put your question below------
I want to use this pogo pin to pass through 1.02 mm hole. I can not see the datasheet as the link is broken.
Can it fit through 1.02 mm hole?
Hi @imak
Welcome to the community!
As per the information available on the manufacturer’s website, part 10114 corresponds to P111A.
Pogo Pin w/ Concave Tip - SparkFun Electronics
And for this you can check the dimensions here: mmexport1760411989975_edit_3963015333315590.jpg
