Die-cut adhesive tape frame
Hi, is a die-cut adhesive tape frame available that goes underneath the screen to mounting?
I’m not aware of any die cut material for use in an application like that. You could reach out to CustomCut.3MProducts@digikey.com with the dimension drawing and the material to see if it can be made.
