When searching for UCZ1J181MNQ1MS on the DigiKey website, you will find UCZ1J181MNJ1MS instead. Is this an error?
No. Here NQ and NJ represent the reflow solder base used for mounting the capacitance as a Surface Mount Component on the substrate or PCB.
As an implementation of a part change notification, PCN2202 (find attached pdf file), the NJ base has replaced NQ as a reflow solder base in these capacitors because it reduces deformation of the base during reflow soldering.
Nichicon_PCN2202_NJ_base_replacing_NQ_base_102722.pdf (862.4 KB)
Note that this PCN (product change notification) is applied to the parts with NQ base styles only and with following series:
“UCD, UUG, UUJ, UUN, UUR, UUX.
Applicable Part Numbers
| Part number | Replacement part number | |
| UCD0J332MNQ1MS | UCD0J332MNJ1MS | |
| UCD0J682MNQ1MS | UCD0J682MNJ1MS | |
| UCD1A222MNQ1MS | UCD1A222MNJ1MS | |
| UCD1C152MNQ1MS | UCD1C152MNJ1MS | |
| UCD1C332MNQ1MS | UCD1C332MNJ1MS | |
| UCD1E102MNQ1MS | UCD1E102MNJ1MS | |
| UCD1E222MNQ1MS | UCD1E222MNJ1MS | |
| UCD1E332MNQ1MS | UCD1E332MNJ1MS | |
| UCD1H331MNQ1MS | UCD1H331MNJ1MS | |
| UCD1H391MNQ1MS | UCD1H391MNJ1MS | |
| UCD1H471MNQ1MS | UCD1H471MNJ1MS | |
| UCD1H681MNQ1GS | UCD1H681MNJ1GS | |
| UCD1H681MNQ1MS | UCD1H681MNJ1MS | |
| UCD1J151MNQ1MS | UCD1J151MNJ1MS | |
| UCD1J221MNQ1MS | UCD1J221MNJ1MS | |
| UCD1J471MNQ1MS | UCD1J471MNJ1MS | |
| UCD1J681MNQ1MS | UCD1J681MNJ1MS | |
| UCD1K101MNQ1MS | UCD1K101MNJ1MS | |
| UCD1K151MNQ1MS | UCD1K151MNJ1MS | |
| UCD1K331MNQ1MS | UCD1K331MNJ1MS | |
| UCD1K471MNQ1MS | UCD1K471MNJ1MS | |
| UCD1K680MNQ1MS | UCD1K680MNJ1MS | |
| UCD1V102MNQ1MS | UCD1V102MNJ1MS | |
| UCD1V471MNQ1MS | UCD1V471MNJ1MS | |
| UCD1V681MNQ1MS | UCD1V681MNJ1MS | |
| UCD2A101MNQ1MS | UCD2A101MNJ1MS | |
| UCD2A151MNQ1MS | UCD2A151MNJ1MS | |
| UCD2A221MNQ1MS | UCD2A221MNJ1MS | |
| UCD2A331MNQ1MS | UCD2A331MNJ1MS | |
| UCD2A470MNQ1MS | UCD2A470MNJ1MS | |
| UCD2A680MNQ1MS | UCD2A680MNJ1MS | |
| UCX1E102MNQ1MS | UCX1E102MNJ1MS | |
| UCX1E122MNQ1MS | UCX1E122MNJ1MS | |
| UCX1E152MNQ1MS | UCX1E152MNJ1MS | |
| UCX1E182MNQ1MS | UCX1E182MNJ1MS | |
| UCX1E222MNQ1MS | UCX1E222MNJ1MS | |
| UCX1E272MNQ1MS | UCX1E272MNJ1MS | |
| UCX1E332MNQ1MS | UCX1E332MNJ1MS | |
| UCX1E821MNQ1MS | UCX1E821MNJ1MS | |
| UCX1H102MNQ1MS | UCX1H102MNJ1MS | |
| UCZ1H102MNQ1MS | UCX1H102MNS1MS | |
| UCX1H122MNQ1MS | UCX1H122MNJ1MS | |
| UCX1H471MNQ1MS | UCX1H471MNJ1MS | |
| UCX1H561MNQ1MS | UCX1H561MNJ1MS | |
| UCX1H681MNQ1MS | UCX1H681MNJ1MS | |
| UCX1H821MNQ1MS | UCX1H821MNJ1MS | |
| UCX1V102MNQ1MS | UCX1V102MNJ1MS | |
| UCX1V122MNQ1MS | UCX1V122MNJ1MS | |
| UCX1V152MNQ6MS | UCX1V152MNJ6MS | |
| UCX1V182MNQ1MS | UCX1V182MNJ1MS | |
| UCX1V471MNQ1MS | UCX1V471MNJ1MS | |
| UCX1V561MNQ1MS | UCX1V561MNJ1MS | |
| UCX1V681MNQ1MS | UCX1V681MNJ1MS | |
| UCX1V821MNQ1MS | UCX1V821MNJ1MS | |
| UCZ1E122MNQ1MS | UCZ1E122MNJ1MS | |
| UCZ1E162MNQ1MS | UCZ1E162MNJ1MS | |
| UCZ1E222MNQ1MS | UCZ1E222MNJ1MS | |
| UCZ1E272MNQ1MS | UCZ1E272MNJ1MS | |
| UCZ1E332MNQ1MS | UCZ1E332MNJ1MS | |
| UCZ1E821MNQ1MS | UCZ1E821MNJ1MS | |
| UCZ1H391MNQ1MS | UCZ1H391MNJ1MS | |
| UCZ1H471MNQ1MS | UCZ1H471MNJ1MS | |
| UCZ1H561MNQ1MS | UCZ1H561MNJ1MS | |
| UCZ1H821MNQ1MS | UCZ1H821MNJ1MS | |
| UCZ1J151MNQ1MS | UCZ1J151MNJ1MS | |
| UCZ1J181MNQ1MS | UCZ1J181MNJ1MS | |
| UCZ1J221MNQ1MS | UCZ1J221MNJ1MS | |
| UUG1A472MNQ6MS | UUG1A472MNJ6MS | |
| UUG1A682MNQ1MS | UUG1A682MNJ1MS | |
| UUG1C102MNQ1MS | UUG1C102MNJ1MS | |
| UUG1C222MNQ1MS | UUG1C222MNJ1MS | |
| UUG1C222MNQ6MS | UUG1C222MNJ6MS | |
| UUG1C332MNQ1MS | UUG1C332MNJ1MS | |
| UUG1C332MNQ6MS | UUG1C332MNJ6MS | |
| UUG1C472MNQ1MS | UUG1C472MNJ1MS | |
| UUG1E102MNQ1MS | UUG1E102MNJ1MS | |
| UUG1E222MNQ1MS | UUG1E222MNJ1MS | |
| UUG1E222MNQ6MS | UUG1E222MNJ6MS | |
| UUG1E332MNQ1MS | UUG1E332MNJ1MS | |
| UUG1E471MNQ1MS | UUG1E471MNJ1MS | |
| UUG1H102MNQ1MS | UUG1H102MNJ1MS | |
| UUG1H221MNQ1MS | UUG1H221MNJ1MS | |
| UUG1H331MNQ1MS | UUG1H331MNJ1MS | |
| UUG1H471MNQ1MS | UUG1H471MNJ1MS | |
| UUG1H471MNQ6MS | UUG1H471MNJ6MS | |
| UUG1J101MNQ1MS | UUG1J101MNJ1MS | |
| UUG1J221MNQ1MS | UUG1J221MNJ1MS | |
| UUG1J331MNQ1MS | UUG1J331MNJ1MS | |
| UUG1J331MNQ6MS | UUG1J331MNJ6MS | |
| UUG1J471MNQ1MS | UUG1J471MNJ1MS | |
| UUG1J471MNQ6MS | UUG1J471MNJ6MS | |
| UUG1V102MNQ1GS | UUG1V102MNJ1GS | |
| UUG1V102MNQ1MS | UUG1V102MNJ1MS | |
| UUG1V102MNQ6MS | UUG1V102MNJ6MS | |
| UUG1V222MNQ1MS | UUG1V222MNJ1MS | |
| UUG1V471MNQ1MS | UUG1V471MNJ1MS | |
| UUG2A101MNQ1MS | UUG2A101MNJ1MS | |
| UUG2A221MNQ1MS | UUG2A221MNJ1MS | |
| UUG2A221MNQ6MS | UUG2A221MNJ6MS | |
| UUG2A331MNQ1MS | UUG2A331MNJ1MS | |
| UUG2A680MNQ1MS | UUG2A680MNJ1MS | |
| UUG2C101MNQ1MS | UUG2C101MNJ1MS | |
| UUG2C101MNQ6MS | UUG2C101MNJ6MS | |
| UUG2C470MNQ1MS | UUG2C470MNJ1MS | |
| UUG2C680MNQ1MS | UUG2C680MNJ1MS | |
| UUG2C680MNQ6MS | UUG2C680MNJ6MS | |
| UUG2D101MNQ1MS | UUG2D101MNJ1MS | |
| UUG2D220MNQ1MS | UUG2D220MNJ1MS | |
| UUG2D330MNQ1MS | UUG2D330MNJ1MS | |
| UUG2D470MNQ1MS | UUG2D470MNJ1MS | |
| UUG2D470MNQ6MS | UUG2D470MNJ6MS | |
| UUG2D680MNQ1MS | UUG2D680MNJ1MS | |
| UUG2D680MNQ6MS | UUG2D680MNJ6MS | |
| UUG2E100MNQ1MS | UUG2E100MNJ1MS | |
| UUG2E220MNQ1MS | UUG2E220MNJ1MS | |
| UUG2E330MNQ1MS | UUG2E330MNJ1MS | |
| UUG2E330MNQ6MS | UUG2E330MNJ6MS | |
| UUG2E470MNQ1MS | UUG2E470MNJ1MS | |
| UUG2E470MNQ6MS | UUG2E470MNJ6MS | |
| UUG2E680MNQ1MS | UUG2E680MNJ1MS | |
| UUG2G100MNQ1MS | UUG2G100MNJ1MS | |
| UUG2G100MNQ6MS | UUG2G100MNJ6MS | |
| UUG2G220MNQ1MS | UUG2G220MNJ1MS | |
| UUG2G220MNQ6MS | UUG2G220MNJ6MS | |
| UUG2G330MNQ1MS | UUG2G330MNJ1MS | |
| UUG2G470MNQ6MS | UUG2G470MNJ6MS | |
| UUG2G4R7MNQ1MS | UUG2G4R7MNJ1MS | |
| UUG2W100MNQ1MS | UUG2W100MNJ1MS | |
| UUG2W100MNQ6MS | UUG2W100MNJ6MS | |
| UUG2W220MNQ1MS | UUG2W220MNJ1MS | |
| UUG2W330MNQ1MS | UUG2W330MNJ1MS | |
| UUG2W4R7MNQ1MS | UUG2W4R7MNJ1MS | |
| UUJ0J102MNQ1MS | UUJ0J102MNJ1MS | |
| UUJ0J222MNQ1MS | UUJ0J222MNJ1MS | |
| UUJ0J222MNQ6MS | UUJ0J222MNJ6MS | |
| UUJ0J332MNQ1MS | UUJ0J332MNJ1MS | |
| UUJ0J332MNQ6MS | UUJ0J332MNJ6MS | |
| UUJ0J472MNQ1MS | UUJ0J472MNJ1MS | |
| UUJ0J682MNQ6MS | UUJ0J682MNJ6MS | |
| UUJ1A102MNQ1MS | UUJ1A102MNJ1MS | |
| UUJ1A222MNQ1MS | UUJ1A222MNJ1MS | |
| UUJ1A222MNQ6MS | UUJ1A222MNJ6MS | |
| UUJ1A332MNQ1MS | UUJ1A332MNJ1MS | |
| UUJ1A332MNQ6MS | UUJ1A332MNJ6MS | |
| UUJ1A472MNQ1MS | UUJ1A472MNJ1MS | |
| UUJ1A682MNQ6MS | UUJ1A682MNJ6MS | |
| UUJ1C102MNQ1MS | UUJ1C102MNJ1MS | |
| UUJ1C102MNQ6MS | UUJ1C102MNJ6MS | |
| UUJ1C222MNQ1MS | UUJ1C222MNJ1MS | |
| UUJ1C222MNQ6MS | UUJ1C222MNJ6MS | |
| UUJ1C332MNQ1MS | UUJ1C332MNJ1MS | |
| UUJ1C471MNQ1MS | UUJ1C471MNJ1MS | |
| UUJ1E102MNQ1MS | UUJ1E102MNJ1MS | |
| UUJ1E102MNQ6MS | UUJ1E102MNJ6MS | |
| UUJ1E222MNQ1MS | UUJ1E222MNJ1MS | |
| UUJ1E331MNQ1MS | UUJ1E331MNJ1MS | |
| UUJ1E471MNQ1MS | UUJ1E471MNJ1MS | |
| UUJ1H102MNQ1MS | UUJ1H102MNJ1MS | |
| UUJ1H221MNQ1MS | UUJ1H221MNJ1MS | |
| UUJ1H331MNQ1MS | UUJ1H331MNJ1MS | |
| UUJ1H331MNQ6MS | UUJ1H331MNJ6MS | |
| UUJ1H471MNQ1MS | UUJ1H471MNJ1MS | |
| UUJ1H471MNQ6MS | UUJ1H471MNJ6MS | |
| UUJ1J101MNQ1MS | UUJ1J101MNJ1MS | |
| UUJ1J221MNQ1MS | UUJ1J221MNJ1MS | |
| UUJ1J221MNQ6MS | UUJ1J221MNJ6MS | |
| UUJ1J331MNQ1MS | UUJ1J331MNJ1MS | |
| UUJ1J331MNQ6MS | UUJ1J331MNJ6MS | |
| UUJ1J471MNQ1MS | UUJ1J471MNJ1MS | |
| UUJ2A331MNQ6MS | UUJ1J471MNJ1MS | |
| UUJ1J680MNQ1MS | UUJ1J680MNJ1MS | |
| UUJ1V102MNQ1MS | UUJ1V102MNJ1MS | |
| UUJ1V102MNQ6MS | UUJ1V102MNJ6MS | |
| UUJ1V221MNQ1MS | UUJ1V221MNJ1MS | |
| UUJ1V222MNQ6MS | UUJ1V222MNJ6MS | |
| UUJ2A331MNQ6MS | UUJ1V222MNJ6MS | |
| UUJ2D101MNQ6MS | UUJ1V222MNJ6MS | |
| UUJ1V331MNQ1MS | UUJ1V331MNJ1MS | |
| UUJ1V471MNQ1MS | UUJ1V471MNJ1MS | |
| UUJ1V471MNQ6MS | UUJ1V471MNJ6MS | |
| UUJ2A101MNQ1MS | UUJ2A101MNJ1MS | |
| UUJ2A101MNQ6MS | UUJ2A101MNJ6MS | |
| UUJ2A221MNQ1MS | UUJ2A221MNJ1MS | |
| UUJ2A221MNQ6MS | UUJ2A221MNJ6MS | |
| UUJ2C680MNQ6MS | UUJ2A221MNJ6MS | |
| UUJ2A470MNQ1MS | UUJ2A470MNJ1MS | |
| UUJ2A680MNQ1MS | UUJ2A680MNJ1MS | |
| UUJ2A680MNQ3MS | UUJ2A680MNJ3MS | |
| UUJ2C101MNQ1MS | UUJ2C101MNJ1MS | |
| UUJ2D470MNQ6MS | UUJ2C101MNJ1MS | |
| UUJ2E330MNQ6MS | UUJ2C101MNJ1MS | |
| UUJ2C330MNQ1MS | UUJ2C330MNJ1MS | |
| UUJ2C470MNQ1MS | UUJ2C470MNJ1MS | |
| UUJ2C470MNQ6MS | UUJ2C470MNJ6MS | |
| UUJ2C680MNQ1MS | UUJ2C680MNJ1MS | |
| UUJ2D100MNQ1MS | UUJ2D100MNJ1MS | |
| UUJ2D101MNQ6MS | UUJ2D101MNJ6MS | |
| UUJ2D220MNQ1MS | UUJ2D220MNJ1MS | |
| UUJ2D330MNQ1MS | UUJ2D330MNJ1MS | |
| UUJ2D330MNQ6MS | UUJ2D330MNJ6MS | |
| UUJ2D470MNQ1MS | UUJ2D470MNJ1MS | |
| UUJ2D680MNQ1MS | UUJ2D680MNJ1MS | |
| UUJ2E100MNQ1MS | UUJ2E100MNJ1MS | |
| UUJ2E220MNQ1MS | UUJ2E220MNJ1MS | |
| UUJ2E220MNQ6MS | UUJ2E220MNJ6MS | |
| UUJ2E330MNQ1MS | UUJ2E330MNJ1MS | |
| UUJ2E470MNQ1MS | UUJ2E470MNJ1MS | |
| UUJ2E4R7MNQ1MS | UUJ2E4R7MNJ1MS | |
| UUJ2E680MNQ6MS | UUJ2E680MNJ6MS | |
| UUJ2G100MNQ1MS | UUJ2G100MNJ1MS | |
| UUJ2G220MNQ1MS | UUJ2G220MNJ1MS | |
| UUJ2G330MNQ6MS | UUJ2G330MNJ6MS | |
| UUJ2G4R7MNQ1MS | UUJ2G4R7MNJ1MS | |
| UUJ2W100MNQ1MS | UUJ2W100MNJ1MS | |
| UUJ2W220MNQ1MS | UUJ2W220MNJ1MS | |
| UUJ2W330MNQ6MS | UUJ2W330MNJ6MS | |
| UUJ2W3R3MNQ1MS | UUJ2W3R3MNJ1MS | |
| UUJ2W4R7MNQ1MS | UUJ2W4R7MNJ1MS | |
| UUN0J102MNQ1MS | UUN0J102MNJ1MS | |
| UUN0J222MNQ1MS | UUN0J222MNJ1MS | |
| UUN0J222MNQ6MS | UUN0J222MNJ6MS | |
| UUN0J332MNQ1MS | UUN0J332MNJ1MS | |
| UUN0J471MNQ1MS | UUN0J471MNJ1MS | |
| UUN1A102MNQ1MS | UUN1A102MNJ1MS | |
| UUN1A222MNQ1MS | UUN1A222MNJ1MS | |
| UUN1A471MNQ1MS | UUN1A471MNJ1MS | |
| UUN1C102MNQ1MS | UUN1C102MNJ1MS | |
| UUN1C102MNQ6MS | UUN1C102MNJ6MS | |
| UUN1C331MNQ1MS | UUN1C331MNJ1MS | |
| UUN1C471MNQ1MS | UUN1C471MNJ1MS | |
| UUN1E102MNQ1MS | UUN1E102MNJ1MS | |
| UUN1E221MNQ1MS | UUN1E221MNJ1MS | |
| UUN1E331MNQ1MS | UUN1E331MNJ1MS | |
| UUN1E471MNQ1MS | UUN1E471MNJ1MS | |
| UUN1H101MNQ1MS | UUN1H101MNJ1MS | |
| UUN1H221MNQ1MS | UUN1H221MNJ1MS | |
| UUN1H221MNQ6MS | UUN1H221MNJ6MS | |
| UUN1H331MNQ1MS | UUN1H331MNJ1MS | |
| UUN1H470MNQ1MS | UUN1H470MNJ1MS | |
| UUN1H471MNQ6MS | UUN1H471MNJ6MS | |
| UUN1J101MNQ1MS | UUN1J101MNJ1MS | |
| UUN1J221MNQ1MS | UUN1J221MNJ1MS | |
| UUN1J331MNQ6MS | UUN1J331MNJ6MS | |
| UUN1J470MNQ1MS | UUN1J470MNJ1MS | |
| UUN1V101MNQ1MS | UUN1V101MNJ1MS | |
| UUN1V221MNQ1MS | UUN1V221MNJ1MS | |
| UUN1V331MNQ1MS | UUN1V331MNJ1MS | |
| UUN1V331MNQ6MS | UUN1V331MNJ6MS | |
| UUN1V471MNQ1MS | UUN1V471MNJ1MS | |
| UUN2A101MNQ1MS | UUN2A101MNJ1MS | |
| UUN2A220MNQ1MS | UUN2A220MNJ1MS | |
| UUN2A330MNQ1MS | UUN2A330MNJ1MS | |
| UUN2A470MNQ1MS | UUN2A470MNJ1MS |
