Digikey Part# 296-42630-ND
I would like to purchase Digikey Part #296-42630-ND. Does it come with the tmp006 tempsensor pouplated on the board, or the board doesn’t come with this temperature sensor pouplated? I will purchase only if the part#296-42630-ND has the temperature sensor pouplated and ready to use. Please let me know at the earliest convenience.
Thank you,
Rahul Mhatre.
Hi rahul.mhatre, welcome to the DigiKey TechForum.
Looking at the MFG Datasheet for 296-42630-ND, it does have the tmp006 sensor. Hopefully this helps but let us know if you have any further questions.
Thanks a lot for your help.
The manufacturer datasheet says, but the one I bought from manufacturer website did not have the sensor pouplated.
Hence the question, does can you guarantee that the sensor is populated on the board you have?
Thanks again
There’s a note in the datasheet addressing this:
So, no, it won’t be populated on a new board. Sorry about that.
