------Question for HK-10.4 Please Put your question below------
Can I please request the dimensions of this product? Do you have the CAD model? Thanks.
Hello @francisco.hernandez
Welcome to the TechForum Community!
Sorry, there is no CAD file available on the manufacturer’s website. The dimensions are as follows:
Hi aayushi, Thanks for providing dimensions. Are you aware whether the barrel with diameter of 6.4 mm can fit a TO-Can laser diode with diameter 5.6 mm. There is a small tolerance there, but not 100% sure whether both parts can be used together.
I do not believe that this will fit the 6.4mm option, you will need to use the 10.4mm size for this diode.
Hi @Rob_Johnson Are you sure? These are the typical dimensions of the laser diode I am thinking of using.
