DIN Rail Mount for Wago Fuses
We are often asked for the DIN rail mount for WAGO fuse 8001-025/K050-0613/002-500 and similar fuses. The part below should be compatible with the parts linked above. Please review the datasheets to ensure it will work for your application.
MFR PART # 282-696
DIGIKEY PART # 2946-282-696-ND
MANUFACTURER WAGO Corporation
DESCRIPTION Terminal Block Connector 2 Position Disconnect Gray 10-24 AWG
DATASHEET Click Here
Applicable Part Numbers
DigiKey Part Number Manufacturer Part Number
2946-8001-025/K050-0613/002-800-ND 8001-025/K050-0613/002-800
2946-8000-099/000-3108-ND 8000-099/000-3108
2946-8001-025/K050-0613/002-6500-ND 8001-025/K050-0613/002-6500
2946-8001-025/K050-0613/002-500-ND 8001-025/K050-0613/002-500
2946-8001-025/K050-0613/002-400-ND 8001-025/K050-0613/002-400
2946-8001-025/K050-0613/002-3700-ND 8001-025/K050-0613/002-3700
2946-8000-0099/0000-5402-ND 8000-0099/0000-5402
2946-8000-099/000-5217-ND 8000-099/000-5217
2946-8000-0099/0000-4163-ND 8000-0099/0000-4163
2946-8001-025/K050-0613/002-1100-ND 8001-025/K050-0613/002-1100
2946-8001-025/K050-0613/002-1300-ND 8001-025/K050-0613/002-1300
