Can some one please advise me what D10 , D14, D3, D2 diodes part number will be?
Thanks
Welcome to the DigiKey tech forum. Do you have a schematic for this board or can you provide a description on the diodes that provides the dimension, voltage and current rating ?
Neither I have schematic nor it has any labels on it that specifies dimension, voltage and current rating.
I don’t see anything legible on those diodes. Are there any markings on the bottom of the part? What are the dimensions length x width x height?
Just a guess, depending on the case size it might be one of these-
0603(1608 Metric) case = 1801-TS4148RCGCT-ND (TS4148 RCG)
0805(2012 Metric) case = 1801-TS4148RBGCT-ND (TS4148 RBG)
1206(3216 Metric) case = 1801-TS4148RAGCT-ND (TS4148 RAG).
I don’t think they actually put the logo on the part. Should look like this with the line.
I don’t have info on the bottom, but I would guess that is probably the correct part then.
Thanks for the help I will try to get this diode and will see if PSU still works.
Thanks
