Good day. I was wondering if anyone has any experience in setting up the DLP DLCR 2000 projector module with the Beagle Bone black? I haven’t been able to find many resources online with regards to configurations and drivers so I was wondering if anyone has already successfully set this up before and could guide me in the right direction.
I’ve attached pictures of the specific components I am referring to.
I have not had any experience with this but someone will come on here and take a look at this for you.
I don’t have any personal experience with this, but as a starting point, have you checked out all of the information in the following links?
- Product highlight for the DLP2000 EVM Several links from here, including the following:
This DLP projector should work out of the box with offical images.
On bootup, u-boot should detect it and enable the video overlay. Then once into Linux a small i2c command is sent over the bus to enable initial output.
If this is not the case, please login over serial/ethernet, and share the output of:
sudo beagle-version
Regards,
