Does the kit set come with carrier board, power supply and require chasing and cables
------Question for SC1924 Please Put your question below------
Hello chincp18,
The datasheet says the Development Kit comprises:
• Raspberry Pi Compute Module 5 Wireless, 4GB RAM, 32GB eMMC (CM5104032)
• Raspberry Pi Compute Module 5 IO Board (supplied pre-fitted inside the IO Case)
• Raspberry Pi IO Case for Raspberry Pi Compute Module 5
• Raspberry Pi Cooler for Raspberry Pi Compute Module 5
• Raspberry Pi Antenna Kit
• Raspberry Pi 27W USB-C PD Power Supply
• 2 × Raspberry Pi HDMI to HDMI Cable
• Raspberry Pi USB-A to USB-C Cable
This kit is designed to be used in the UK, so the power supply will be for the UK.
