The B84143G0090R110 EMC filter has been withdrawn from the manufacturer as shown below and found here, but they have suggested an option B84243A6083Z000 that could work as an alternative. Please note that this is not a direct replacement, but the specs are similar. Please check the datasheet to ensure this alternative will fit your application.
| MFR PART # | B84243A6083Z000 |
| DIGIKEY PART # | B84243A6083Z000-ND |
| MANUFACTURER | EPCOS - TDK Electronics |
| DESCRIPTION | Three Phase (Delta) EMC/EMI Line Filter 83 A 530V, 305V 50/60Hz Single Stage Terminal Block |
