hello can you try using this code. there have been some optimizations made
// colors: 0 = Red, 32 = Orange, 64 = Yellow, 96 = Green, 128 = Aqua, 160 = Blue, 192 = Purple, 224 = Pink
#include <FastLED.h>
#include <Wire.h>
#include <MPU6050.h>
#include // For std::sort
// Pin definitions
#define LED_PIN 5
#define SDA_PIN 21
#define SCL_PIN 22
#define BUTTON_PIN 4 // Button for color switching
#define NUM_LEDS 256
#define MATRIX_WIDTH 16
#define MATRIX_HEIGHT 16
#define FLUID_PARTICLES 64
#define BRIGHTNESS 30
#define NUM_COLORS 3 // Number of color options
// Structures
struct Vector2D {
float x;
float y;
struct Particle {
Vector2D position;
Vector2D velocity;
// Global variables
CRGB leds[NUM_LEDS];
MPU6050 mpu;
Particle particles[FLUID_PARTICLES];
Vector2D acceleration = {0, 0};
// Color switching variables
uint8_t currentColorIndex = 0;
unsigned long lastDebounceTime = 0;
const unsigned long debounceDelay = 200;
// Define the colors (you can change these hue values)
const uint8_t COLORS[NUM_COLORS] = {
160, // Blue
0, // Red
96 // Green
// Mutex for synchronization (ESP32 style)
portMUX_TYPE dataMux = portMUX_INITIALIZER_UNLOCKED;
// Constants for physics
const float GRAVITY = 0.08f;
const float DAMPING = 0.92f;
const float MAX_VELOCITY = 0.6f;
// Forward declarations
void initMPU6050();
void initLEDs();
void initParticles();
void updateParticles();
void drawParticles();
void MPUTask(void *parameter);
void LEDTask(void *parameter);
void checkButton();
// Function to convert x,y coordinates to LED index
inline int xy(int x, int y) {
x = constrain(x, 0, MATRIX_WIDTH - 1);
y = constrain(y, 0, MATRIX_HEIGHT - 1);
// Zigzag mapping
return (y & 1) ? (y * MATRIX_WIDTH + (MATRIX_WIDTH - 1 - x)) : (y * MATRIX_WIDTH + x);
void checkButton() {
static bool lastButtonState = HIGH;
bool buttonState = digitalRead(BUTTON_PIN);
if (buttonState == LOW && lastButtonState == HIGH) {
if (millis() - lastDebounceTime > debounceDelay) {
currentColorIndex = (currentColorIndex + 1) % NUM_COLORS;
lastDebounceTime = millis();
lastButtonState = buttonState;
void drawParticles() {
FastLED.clear();
// Keep track of which (x,y) cells are occupied
static bool occupied[MATRIX_WIDTH][MATRIX_HEIGHT];
memset(occupied, false, sizeof(occupied));
// Sort the particles by "y * width + x" so we draw them in ascending order
// (or any other criterion you want). This helps ensure consistent layering.
std::sort(particles, particles + FLUID_PARTICLES, [&](const Particle &a, const Particle &b){
float posA = a.position.y * MATRIX_WIDTH + a.position.x;
float posB = b.position.y * MATRIX_WIDTH + b.position.x;
return posA < posB;
// Now draw the particles in that order
for (int i = 0; i < FLUID_PARTICLES; i++) {
int x = round(particles[i].position.x);
int y = round(particles[i].position.y);
// Constrain coordinates
if (!occupied[x][y]) {
int index = xy(x, y);
if (index >= 0 && index < NUM_LEDS) {
// Compute brightness based on velocity magnitude
float vx = particles[i].velocity.x;
float vy = particles[i].velocity.y;
float speed = sqrtf(vx*vx + vy*vy);
// Make it glow more if faster
uint8_t hue = COLORS[currentColorIndex];
uint8_t sat = 255;
uint8_t val = constrain((int)(180 + speed * 50), 180, 255);
leds[index] = CHSV(hue, sat, val);
occupied[x][y] = true;
else {
// Try to place the particle near its position if (x,y) is already occupied
bool placed = false;
for (int r = 1; r < 3 && !placed; r++) {
for (int dx = -r; dx <= r && !placed; dx++) {
for (int dy = -r; dy <= r && !placed; dy++) {
if (abs(dx) + abs(dy) == r) {
int newX = x + dx;
int newY = y + dy;
if (newX >= 0 && newX < MATRIX_WIDTH &&
newY >= 0 && newY < MATRIX_HEIGHT &&
!occupied[newX][newY])
int index = xy(newX, newY);
leds[index] = CHSV(COLORS[currentColorIndex], 255, 180);
occupied[newX][newY] = true;
placed = true;
FastLED.show();
void updateParticles() {
// Safely read current accel from shared variable
Vector2D currentAccel;
portENTER_CRITICAL(&dataMux);
currentAccel = acceleration;
portEXIT_CRITICAL(&dataMux);
// Scale it down a bit so it feels "softer"
currentAccel.x *= 0.3f;
currentAccel.y *= 0.3f;
// Update positions and velocities
Particle &p = particles[i];
p.velocity.x = p.velocity.x * 0.9f + (currentAccel.x * GRAVITY);
p.velocity.y = p.velocity.y * 0.9f + (currentAccel.y * GRAVITY);
p.velocity.x = constrain(p.velocity.x, -MAX_VELOCITY, MAX_VELOCITY);
p.velocity.y = constrain(p.velocity.y, -MAX_VELOCITY, MAX_VELOCITY);
float newX = p.position.x + p.velocity.x;
float newY = p.position.y + p.velocity.y;
// Bounce off walls with damping
if (newX < 0.0f) {
newX = 0.0f;
p.velocity.x = fabsf(p.velocity.x) * DAMPING;
else if (newX >= (MATRIX_WIDTH - 1)) {
newX = MATRIX_WIDTH - 1;
p.velocity.x = -fabsf(p.velocity.x) * DAMPING;
if (newY < 0.0f) {
newY = 0.0f;
p.velocity.y = fabsf(p.velocity.y) * DAMPING;
else if (newY >= (MATRIX_HEIGHT - 1)) {
newY = MATRIX_HEIGHT - 1;
p.velocity.y = -fabsf(p.velocity.y) * DAMPING;
p.position.x = newX;
p.position.y = newY;
// Slow the particles slightly
p.velocity.x *= 0.95f;
p.velocity.y *= 0.95f;
// Very simple collision/repulsion: O(N^2) for 64 particles is still fine.
Particle &pi = particles[i];
for (int j = i + 1; j < FLUID_PARTICLES; j++) {
Particle &pj = particles[j];
float dx = pj.position.x - pi.position.x;
float dy = pj.position.y - pi.position.y;
float distSq = dx*dx + dy*dy;
// If they are within a small range, push them apart
if (distSq < 1.0f && distSq > 0.0f) {
float distance = sqrtf(distSq);
// Normalize (dx, dy)
dx /= distance;
dy /= distance;
// Repulsion
float repulsion = 0.3f; // tweak to taste
pi.position.x -= dx * 0.5f * repulsion;
pi.position.y -= dy * 0.5f * repulsion;
pj.position.x += dx * 0.5f * repulsion;
pj.position.y += dy * 0.5f * repulsion;
// Average out velocity so they don't explode outward
Vector2D avgVel = {
(pi.velocity.x + pj.velocity.x) * 0.5f,
(pi.velocity.y + pj.velocity.y) * 0.5f
pi.velocity = avgVel;
pj.velocity = avgVel;
void initMPU6050() {
Serial.println(“Initializing MPU6050…”);
mpu.initialize();
if (!mpu.testConnection()) {
Serial.println("MPU6050 connection failed!");
while (true) { delay(100); }
// ±2g range for accelerometer
mpu.setFullScaleAccelRange(MPU6050_ACCEL_FS_2);
Serial.println("MPU6050 initialized");
void initLEDs() {
Serial.println(“Initializing LEDs…”);
FastLED.addLeds<WS2812B, LED_PIN, GRB>(leds, NUM_LEDS);
FastLED.setBrightness(BRIGHTNESS);
FastLED.clear(true);
Serial.println(“LEDs initialized”);
void initParticles() {
Serial.println(“Initializing particles…”);
int index = 0;
// Place the particles near the bottom rows
for (int y = MATRIX_HEIGHT - 4; y < MATRIX_HEIGHT; y++) {
for (int x = 0; x < MATRIX_WIDTH && index < FLUID_PARTICLES; x++) {
particles[index].position = { (float)x, (float)y };
particles[index].velocity = { 0.0f, 0.0f };
index++;
Serial.printf("Total particles initialized: %d\n", index);
// Task that reads from the MPU and updates global acceleration
void MPUTask(void *parameter) {
while (true) {
int16_t ax, ay, az;
mpu.getAcceleration(&ax, &ay, &az);
// Convert raw readings to ~[-2, 2] range and constrain to [-1, 1]
acceleration.x = -constrain(ax / 16384.0f, -1.0f, 1.0f);
acceleration.y = constrain(ay / 16384.0f, -1.0f, 1.0f);
// 10ms delay is fine for reading the accelerometer
vTaskDelay(pdMS_TO_TICKS(10));
// Task that updates and draws the particles
void LEDTask(void *parameter) {
TickType_t xLastWakeTime = xTaskGetTickCount();
const TickType_t xFrequency = pdMS_TO_TICKS(16); // ~60 FPS
while (true) {
checkButton();
updateParticles();
drawParticles();
// Wait until the next frame
vTaskDelayUntil(&xLastWakeTime, xFrequency);
void setup() {
Serial.begin(115200);
delay(1000);
Serial.println(“Starting initialization…”);
pinMode(BUTTON_PIN, INPUT_PULLUP);
Wire.begin(SDA_PIN, SCL_PIN);
Wire.setClock(400000);
initMPU6050();
initLEDs();
initParticles();
// Create tasks on separate cores (ESP32)
xTaskCreatePinnedToCore(
MPUTask,
"MPUTask",
4096,
NULL,
2,
NULL,
0
LEDTask,
"LEDTask",
4096,
NULL,
1,
NULL,
1
Serial.println("Setup complete");
void loop() {
// Nothing here, tasks do all the work
vTaskDelete(NULL);
