EV_MOD_CH201-00-01 cable
This part is a breakout eval module for the TDK Chirp CH201. Does this come with the ribbon cable? The data sheet has reference to a table of molex ribbon cables but doesn’t indicate which row is correct.
Greetings,
No cable is included. The user guide indicates that an 8-conductor interconnect is required, so one would want to select from the 8-position row of the referenced drawing, based on desired length and same/opposite side configuration.
In-stock listings meeting the 8-position/0.5mm pitch criteria can be found here.
Great. So the type A/type D refers to the conducting pins being on the same side / opposite side?
Yes, that’s correct.
