FAQ: Can modifications to standard enclosures be ordered through DigiKey?
In many instances, yes. Because enclosure products typically require the addition of holes, slots, or other features prior to use, many major manufacturers of such products offer additional machining/processing on standard products as a value-added service.
Requests may be made through DigiKey by sending a message with the following to modenclosures@digikey.com:
A. DigiKey customer number and Contact Information.
B. DigiKey part number of the standard product to be modified
C. Quantity of enclosures to be modified
D. A properly dimensioned drawing or .STP file showing the modifications required.
Minimum orders and/or setup fees will apply and vary by supplier. Inquiries consummated through delivery of product will be assigned a DigiKey part number, which can be referenced for re-ordering purposes.
See also this post for additional information on this topic.
Click here to return to FAQ index.
