What is the part number for the “female counterpart” to part number 1731090327 ?
Welcome to the DigiKey TechForum. Take a look at DigiKey part 900-1731090446-ND as a cable mount option.
Thanks Steve !!!
Does these connectors come with “loose” crimp-pins:
1731090327-ND ?
1731090446-ND ?
1003-1751-ND ?
1003-1752-ND ?
Hello ks1,
Yes all those parts you listed will have the contacts included in the package.
Thanks again Steve !!!
Last question (I hope
Plz confirm that the crimp tool:
2057-ATHT-001-ND
will work on all 4 above crimp-pin connectors
Kind regards, Klaus
Steve: can I kindly ask you to answer my latest question ?
It may be possible that the 2057-ATHT-001-ND would work as long as you are using wire in the 20-26awg range.
The contacts for the 1003-1751-ND and the 1003-1752-ND can use wire down to 28awg so.
– As long as you are not using wire smaller than 26 it may be fine.
I am sorry to say that Molex does not list a hand tool for either of their items currently.
ITT_Cannon_Mil_Aero D-Subminiature_Catalog.pdf (2.8 MB)
For the ITT items they list tooling in their catalog(attached above) on page 15.
For the hand tool that would handle the #20 contacts that this document lists that the ITT Cannon items come with I found the below.
Hand tool (spec M22520/2-01)
A9977-ND
601966-1 TE Connectivity Application Tooling | Crimpers, Applicators, Presses | DigiKey
Locator (spec M22520/2-08)
A9797-ND
601966-5 TE Connectivity Application Tooling | Crimp Heads, Die Sets | DigiKey
Jumping on what Nathan has said, the tool from Adam Tech (2057-ATHT-001-ND) is likely going to work for crimping wires to these connector contacts, though it can’t be guaranteed when tooling across different manufacturers. It’s still fairly common practice but you will need to be aware of that caveat.
However, if you need to meet any of the MIL specs listed in Nathan’s post, you must use the ITT Cannon recommended tools.
Thanks to both of you ![]()
