Ferroxcube Vertical Bobbin (Coil Former) D Suffix Meaning
If you are looking for the vertical Bobbin (Coil Former) from Ferroxcube, you may see there is a D suffix at this end of part number, such as CPV-PQ32/20-1S-12PD-Z.
Please see below per the manufacturer:
The D stands for a side terminal pins which allows you to easily make a transformer with flying leads. On the CPV-PQ32/20-1S-12PD-Z you can connect the wires to the pins on the side. On the CPV-PQ32/20-1S-12P-Z you can only connect the wire to the pins on the bottom. See below.
Applicable part numbers
DK Part # Mfr Part #
1779-1401-ND CPV-RM6S/I-1S-8PD-TZ
1779-1358-ND CPV-E25/13/11-1S-8P
1779-1403-ND CPV-RM8/I-1S-12PD-TZ
1779-1424-ND CSV-PQ20/20-1S-14P
1779-1385-ND CPV-PQ26/20-1S-12P-Z
1779-1383-ND CPV-PQ20/20-1S-14P-Z
1779-1397-ND CPV-RM12/I-1S-12PD-TZ
1779-1381-ND CPV-PQ20/16-1S-14P-Z
1779-1386-ND CPV-PQ26/25-1S-12PD-Z
1779-1391-ND CPV-PQ32/30-1S-12P-Z
1779-1389-ND CPV-PQ32/20-1S-12P-Z
1779-1390-ND CPV-PQ32/30-1S-12PD-Z
1779-1392-ND CPV-PQ35/35-1S-12P-Z
1779-1374-ND CPV-P26/16-2S-6PDL-Z
1779-1427-ND CSV-PQ50/50-1S-12P
1779-1423-ND CSV-E25/13/7-1S-6P-C
1779-1384-ND CPV-PQ26/20-1S-12PD-Z
1779-1372-ND CPV-P26/16-1S-6PDL-Z
1779-1361-ND CPV-P14/8-1S-6PD-Z
1779-1365-ND CPV-P18/11-1S-6PDL
1779-1377-ND CPV-P30/19-1S-6PDL-Z
1779-1360-ND CPV-P14/8-1S-4SPD-Z
1779-1370-ND CPV-P22/13-1S-6PD-Z
1779-1394-ND CPV-RM10/I-1S-12PD-TZ
1779-1382-ND CPV-PQ20/20-1S-14PD-Z
1779-1399-ND CPV-RM14/I-1S-12PD-TZ
1779-1426-ND CSV-PQ40/40-1S-12P
1779-1425-ND CSV-PQ26/25-1S-12P-ZF
1779-1388-ND CPV-PQ32/20-1S-12PD-Z
1779-1373-ND CPV-P26/16-1S-6PD-Z
1779-1359-ND CPV-E25/13/7-1S-10P-Z
1779-1363-ND CPV-P14/8-2S-6PDL-Z
1779-1364-ND CPV-P14/8-2S-6PD-Z
1779-1375-ND CPV-P26/16-3S-6PDL-Z
1779-1387-ND CPV-PQ26/25-1S-12P-Z
1779-1357-ND CPV-E20/10/5-1S-6P
1779-1376-ND CPV-P26/16-3S-6PD-Z
1779-1366-ND CPV-P18/11-1S-6PD-Z
1779-1369-ND CPV-P22/13-1S-6PDL-Z
1779-1371-ND CPV-P22/13-3S-6PD-Z
1779-1378-ND CPV-P30/19-1S-6PD-Z
1779-1379-ND CPV-PM50/39-1S-14PD-C
1779-1362-ND CPV-P14/8-2S-4SPD-Z
1779-1368-ND CPV-P18/11-3S-6PD-Z
1779-1367-ND CPV-P18/11-2S-6PD-Z
1779-CSV-RM4-2S-5P-C-ND CSV-RM4-2S-5P-C
1779-CSV-RM4-1S-5P-C-ND CSV-RM4-1S-5P-C
1779-CSV-RM4-1S-6P-C-ND CSV-RM4-1S-6P-C
1779-CPVS-ER9.5-1S-8P-C-ND CPVS-ER9.5-1S-8P-C
1779-CSV-RM5-1S-4P-C-ND CSV-RM5-1S-4P-C
1779-CSV-RM7-2S-8P-TZ-ND CSV-RM7-2S-8P-TZ
1779-CSV-RM7-1S-4P-C-ND CSV-RM7-1S-4P-C
1779-CSV-RM7-1S-8P-C-ND CSV-RM7-1S-8P-C
1779-CSV-RM7-1S-5P-C-ND CSV-RM7-1S-5P-C
1779-CSV-RM5-1S-6P-TZ-ND CSV-RM5-1S-6P-TZ
1779-CSV-RM6S/R-2S-4P-C-ND CSV-RM6S/R-2S-4P-C
1779-CSV-RM8-2S-8P-C-ND CSV-RM8-2S-8P-C
1779-CSV-RM8-2S-12P-C-ND CSV-RM8-2S-12P-C
1779-CSV-RM6S-1S-4P-TZ-ND CSV-RM6S-1S-4P-TZ
1779-CSV-EQ30/16/20-1S-10P-Z-ND CSV-EQ30/16/20-1S-10P-Z
1779-CSV-RM6S-1S-6P-TZ-ND CSV-RM6S-1S-6P-TZ
1779-CSV-RM8/LP-1S-10P-ZA-ND CSV-RM8/LP-1S-10P-ZA
1779-CSV-RM8/LP-1S-12P-Z-ND CSV-RM8/LP-1S-12P-Z
1779-CPVS-ER9.5-1S-8P-Z-ND CPVS-ER9.5-1S-8P-Z
1779-CSV-RM8-1S-8P-TA-ND CSV-RM8-1S-8P-TA
1779-CSVS-RM6S-1S-8P-B-ND CSVS-RM6S-1S-8P-B
1779-CSV-RM8-1S-4P-C-ND CSV-RM8-1S-4P-C
1779-CPVS-RM6S/LP-1S-8P-B-C-ND CPVS-RM6S/LP-1S-8P-B-C
1779-CSV-RM10-1S-5P-C-ND CSV-RM10-1S-5P-C
1779-CSVS-RM6S-1S-8P-ND CSVS-RM6S-1S-8P
1779-CSVS-RM5-1S-8P-Z-ND CSVS-RM5-1S-8P-Z
1779-CPVS-ER14.5-1S-10P-Z-ND CPVS-ER14.5-1S-10P-Z
1779-CSV-PT23/11-1S-10P-C-ND CSV-PT23/11-1S-10P-C
1779-CSV-RM8-1S-12P-C-ND CSV-RM8-1S-12P-C
1779-CPVS-ER11-1S-12P-Z-ND CPVS-ER11-1S-12P-Z
1779-CSV-RM10-1S-8P-C-ND CSV-RM10-1S-8P-C
1779-CSV-RM10-1S-10P-C-ND CSV-RM10-1S-10P-C
1779-CSVS-RM4/LP-1S-8P-Z-ND CSVS-RM4/LP-1S-8P-Z
1779-CSVS-RM4/LP-1S-8PL-ND CSVS-RM4/LP-1S-8PL
1779-CPVS-ER11-1S-10P-Z-ND CPVS-ER11-1S-10P-Z
1779-CSV-RM10-2S-8P-C-ND CSV-RM10-2S-8P-C
1779-CSVS-RM6S-1S-8P-T-ND CSVS-RM6S-1S-8P-T
1779-CPVS-RM4-1S-6P-ND CPVS-RM4-1S-6P
1779-CSVS-RM7-1S-8P-Z-ND CSVS-RM7-1S-8P-Z
1779-CPV-ETD34-1S-14P-C-ND CPV-ETD34-1S-14P-C
1779-CSV-RM6R-1S-6P-IZ-C-ND CSV-RM6R-1S-6P-IZ-C
1779-CPV-RM5-1S-8PD-Z-ND CPV-RM5-1S-8PD-Z
1779-CSV-RM10-1S-12P-C-ND CSV-RM10-1S-12P-C
1779-CSV-RM12-1S-12P-TZ-ND CSV-RM12-1S-12P-TZ
1779-CSV-RM12-1S-11P-T-ND CSV-RM12-1S-11P-T
1779-CPV-PT14/8-1S-6P-Z-ND CPV-PT14/8-1S-6P-Z
1779-CPV-PT23/18-1S-10P-Z-ND CPV-PT23/18-1S-10P-Z
1779-CPV-PT23/11-1S-10P-Z-ND CPV-PT23/11-1S-10P-Z
1779-CSV-RM14-1S-12P-CL-ND CSV-RM14-1S-12P-CL
1779-CSV-RM14-1S-10P-C-ND CSV-RM14-1S-10P-C
1779-CSV-RM14-1S-12P-C-ND CSV-RM14-1S-12P-C
1779-CPV-PT30/19-1S-10P-Z-ND CPV-PT30/19-1S-10P-Z
1779-CSV-RM6S/R-1S-4P-IZ-ND CSV-RM6S/R-1S-4P-IZ
1779-CSV-RM10-1S-10P-ND CSV-RM10-1S-10P
1779-CSV-RM6S-1S-8P-ND CSV-RM6S-1S-8P
1779-CSV-RM6S/R-2S-4P-IZ-ND CSV-RM6S/R-2S-4P-IZ
1779-CSV-RM8-1S-8P-G-ND CSV-RM8-1S-8P-G
1779-CSV-RM6S-1S-5P-G-ND CSV-RM6S-1S-5P-G
1779-CSV-RM8-2S-12P-ND CSV-RM8-2S-12P
1779-CSV-RM10-1S-12P-ND CSV-RM10-1S-12P
1779-CSV-RM8-1S-12P-G-ND CSV-RM8-1S-12P-G
1779-CSV-RM6S-1S-6P-G-ND CSV-RM6S-1S-6P-G
1779-CSV-RM8-2S-8PL-ND CSV-RM8-2S-8PL
1779-CSV-RM8-1S-4P-ND CSV-RM8-1S-4P
1779-CSV-RM10-1S-5P-ND CSV-RM10-1S-5P
1779-CSVS-RM5-1S-8P-ND CSVS-RM5-1S-8P
1779-CSV-RM8-2S-8P-ND CSV-RM8-2S-8P
1779-CSV-RM6R-2S-6P-IZ-ND CSV-RM6R-2S-6P-IZ
1779-CSV-RM8-1S-8PL-ND CSV-RM8-1S-8PL
1779-CSV-RM8-1S-5P-ND CSV-RM8-1S-5P
1779-CSVS-RM5/LP-1S-8P-ND CSVS-RM5/LP-1S-8P
1779-CSVS-RM6S/LP-1S-8P-ND CSVS-RM6S/LP-1S-8P
1779-CSV-RM4-1S-5P-ND CSV-RM4-1S-5P
1779-CSV-RM10-2S-12P-ND CSV-RM10-2S-12P
1779-CSV-RM7/I-1S-8P-ND CSV-RM7/I-1S-8P
1779-CSV-RM10-1S-8P-ND CSV-RM10-1S-8P
1779-CSV-RM5-2S-6P-ND CSV-RM5-2S-6P
1779-CSV-RM8-2S-5P-ND CSV-RM8-2S-5P
1779-CSV-RM10-2S-8P-ND CSV-RM10-2S-8P
1779-CSV-RM5-2S-4P-IZ-ND CSV-RM5-2S-4P-IZ
1779-CSVS-RM6S/LP-1S-8P-B-ND CSVS-RM6S/LP-1S-8P-B
1779-CSV-RM4-2S-5P-ND CSV-RM4-2S-5P
1779-CSV-RM4-1S-6P-ND CSV-RM4-1S-6P
1779-CSV-RM5-1S-4P-IZ-ND CSV-RM5-1S-4P-IZ
1779-CSV-RM5-1S-6P-G-ND CSV-RM5-1S-6P-G
1779-CSV-RM5-1S-5P-ND CSV-RM5-1S-5P
1779-CSV-RM4-2S-6P-ND CSV-RM4-2S-6P
