Finding a replacement for blown Audio Amp IC
A customer brought in a PCB for a Halloween decoration, they plugged in a 24v power brick instead of the 6v one it came with.
Most of the circuitry seems fine, however this audio IC is badly damaged. I need help finding it.
I am pretty sure it is an LTK5210 SOP-10. The problem is I cannot find aLTK5210 on Mouser or DigiKey only on Aliexpress. This is a priority repair and getting from China would likely take too long.
If it is what I think it is does anyone have a US supplier for it, or is there any other more common ICs that would work in its place that can be found on DigiKey or mouser?
Regardless, thank you for y’alls help.
Hello, welcome to the Techforum!
I tried searching for more information on your IC, but unfortunately I was unable to find a datasheet to cross this part over to something we carry.
Here is the datasheet!
http://www.chiphometek.com/datasheet/LTK5210.pdf
Kind of hard to find and all in chinese. But I was able to find it. But I dont know enough about audio component to find a suitable replacement.
Its was hard to find but I was able to find the datasheet and I linked it.
Hello @braxtonfts
Sorry, I am unable to find a DigiKey replacement for a stereo audio amplifier in an ESOP-10 package with an exposed pad.
The closest items I was able to locate are listed here.
Best wishes,
