Good day. I am looking for a 21 pin HDMI port with three mounting pins for PCB mounting. You can see the connector at:
https://www.aliexpress.com/item/1005005812246078.html
PLease let me know if you can provide a NA solution.
Hello bwilliams60,
The closest option we offer in our system, is part number 5622-52C21B02131TR-ND.
This is a marketplace product, and has a minimum order quantity of 10 pieces.
Please check the Datasheet Drawing, as it show extra mounting pins on the side.
Also on the datasheet, also verify the pad layout, and the spacing of the support pins.
We do not have an exact match to that connector.
