Heat Exchanger Differences
I recently was asked the difference between these two similar Boyd Woburn Heat Exchangers.
M05-050AN1 and M05-050SB1
The primary difference between the M05-050AN1 and the M05-050SB1 is the type of fluid connection port built into the heat exchanger. Both models are copper-tubed, aluminum tube-fin, liquid-to-air OEM heat exchangers manufactured by Aavid (a thermal division of Boyd Corporation), sharing the same thermal capacities and baseline core specifications.
please refer to the chart comparing differences.
