Hello all
Got this pfc from DigiKey and the dimple on the one I received doesn’t have it, just a dash. When I look at the datasheet I can’t tell which way it should be placed. See the pics.
Thanks in advance
Hello timurrenee,
The datasheet for the FAN7930CMX-GCT-ND part, just shows the dimple. The IC should all have an indication of what end of the chip is the #1 terminal. So with the line on that side, that is where the #1 terminal will be. So the #1 terminal will be in the corner, by the bar, below the HATG markings.
Thank you so much for your help
