Hello DigiKey community!
When a customer asks me to compare parts I make them a compare chart.
One way to make a compare chart is to use the Digikey Search bar.
If the parts are in the same category multiple parts can be searching using the | key (the vertical bar key). We also call the key the or key. It is located above the enter key.
The part numbers need to be in the same category and DigiKey part numbers.
Manufacture part numbers will not work with this search.
Then the search will bring me to a page with all the parts I just searched for.
I like comparing parts side by side, so I use the compare products search button.
Use the check boxes located on the left side of the product list then push compare products button.
