Introduction
So far in our discussion, we’ve explored the fundamentals of power topologies and their design considerations. We started with “An Insight into Power Topologies and Design Considerations”, covering the basics of power supply design.
Then explored “ Understanding Isolated Power Topologies”, focusing on when and why isolation is needed.
Finally, we discussed “Non-Isolated Switching Power Supplies”, highlighting their topologies, working, and use cases.
Now that we’ve laid the groundwork, the real question arises:
How do you choose the right topology?
In the upcoming section, we’ll walk through the key factors — such as power requirements, output voltage needs, isolation, efficiency, and cost — to help you confidently choose the most suitable power topology for your application.
Key Factors to Consider When Choosing the Right Power Topology
1. Power Requirements: First, consider the power requirements you need from your power solution.
- For < 10W → , linear power supplies, Buck, Boost, or Flyback topologies are suitable.
- For 10W – 100W → Flyback, Forward, or Half-Bridge topologies can be used.
- For > 100W → Full-Bridge or LLC Resonant topologies.
2. Output Voltage Requirements:
- If only step-down is needed → Buck or Flyback.
- If only step-up is needed → Boost topologies are suitable.
- If both step-up & step-down are needed → Buck-Boost or SEPIC topologies can be used.
3. Isolation Needs:
- If isolation is required → Flyback, Forward, or LLC Resonant topologies can be used.
- If isolation is not needed → Buck or Boost topologies are suitable.
4. Efficiency & Cost Balance:
- For high efficiency → LLC Resonant or Full-Bridge topologies are suitable.
- For lower cost → Buck or Flyback topologies are better choices.
Different topologies have their own advantages and disadvantages and the choice should be based on the application requirements, balancing efficiency, cost, and size.
| Topology Type | Working Principle | Advantages | Disadvantages | Applicable Applications |
| Linear Power Supply (LDO, Linear Regulator) | Reduces voltage through linear regulation, converting excess energy into heat | Low noise, low ripple, simple design | Low conversion efficiency (<50%), generates heat | Precision electronic devices, audio amplifiers, low-power MCU power supply |
| Buck Converter | Uses switching to control inductor energy storage and release, stepping down high voltage to low voltage | High efficiency (above 80%), simple circuit | Can only step-down voltage, not step up | DC-DC conversion, battery-powered devices, automotive electronics |
| Boost Converter | Uses inductor energy storage to increase output voltage | Can step-up low voltage to the required level | Requires large current switching transistors, high power applications generate more EMI | Boosting lithium battery voltage to 5V USB, LED drivers |
| Buck-Boost Converter | Provides an output voltage either higher or lower than the input depending on variations | Flexible adaptation to input changes | Slightly lower efficiency compared to buck or boost converters | Battery-powered devices, power banks, portable devices |
| SEPIC Converter | Similar to buck-boost, but output voltage maintains the same polarity as the input | Can provide voltage higher or lower than input, avoids polarity inversion | Requires additional coupling capacitors, complex design | Automotive electronics, applications with variable input voltage |
| Flyback Converter | Uses transformer energy storage and release, suitable for low-power isolated applications | Simple structure, supports multiple output voltages | High EMI, lower efficiency compared to forward converters | Chargers, small adapters, standby power supplies |
| Forward Converter | Transformer directly transfers energy, suitable for medium-power applications | Higher efficiency than flyback, suitable for higher power | Requires additional filter inductors, more complex circuit | Industrial power supplies, communication equipment |
| Half-Bridge Converter | Two switching diodes operate alternately, energy is transferred via a transformer | High efficiency, suitable for medium to high-power applications | Requires additional control circuits, more complex design | LCD TVs, servo drive power supplies |
| Full-Bridge Converter | A bridge circuit composed of four switching diodes, suitable for high-power applications | High efficiency, suitable for large power loads | High switching losses, complex control | Servo drives, high-power industrial power supplies |
| LLC Resonant Converter | Uses resonance to reduce switching losses and improve efficiency | High efficiency, low EMI, suitable for high-power applications | Complex design, requires precise matching of inductance and capacitance | Servo drives, high-performance power supplies, server power |
Conclusion
Power supply design plays a crucial role in electronic engineering, directly influencing the system’s stability, efficiency, and reliability. A solid understanding of various power topologies allows designers to select the best-fit solution based on the application’s needs. For instance, linear regulators are ideal for low-power, low-noise situations, while switching mode power supplies excel in high-power, high-efficiency applications.
Beyond topology, factors like EMI suppression, thermal management, PCB layout, and component selection are key to achieving optimal performance and extending the lifespan of power supplies.
With continuous technological progress, innovations like digital power control, GaN (Gallium Nitride), and SiC (Silicon Carbide) devices are pushing the boundaries of efficiency and power density, helping modern electronic systems become smarter and more energy-efficient. Moving forward, the focus will remain on refining power topologies, minimizing losses, and maximizing energy efficiency.
To help you quickly understand power supply design solutions and related technologies, DigiKey has introduced the main power electronics topologies, discrete power components, power management integrated circuits (PMICs), power supplies, and thermal management solutions on the following webpage. You can visit the following link to learn more about power supply technologies: Power Solutions & Technologies | DigiKey
Related Article
Non-Isolated Switching Power Supplies — Topologies & Use Cases
Understanding Isolated Power Topologies: Design Principles and Use Cases
