------Question for MS3106A22-23P Please Put your question below------
I need the female connector (female pins) to connect to MS3106A22-23P (8Pin). Could you help me with the reference number?
Thanks
Thanks
Hello @jesus.ortega
Welcome to the TechForum community!
For the mating part of MS3106A22-23P, you can check the end of the part description page.
The mating female connector for MS3106A22-23P is MS3102A22-23S.
MS3106A22-23P Amphenol Industrial Operations | Connectors, Interconnects | DigiKey Marketplace
Thank you for your help. The one you are suggesting is for panel mounting, but I need one for cable mounting (cable connecting plug). Could you help me find this one?
Could this be it?
Hello @jesus.ortega
Part 97-3101A-22-23S should mate with MS3106A22-23P, as both share the same shell size (22) and insert arrangement (22-23).
As per the 97-series datasheet, these connectors are compatible: “Mates with all types of MS receptacles.”
ok, gracias. realizare el pedido de este material
