Identify diode or transistor
Anyone have any ideea what is this SMD with marking
5G30A
5G30A
I google it… and nothing :frowning:
Thanks
Hello @Max
Thank you for using our TechForum. We are checking on this product to see if we can identify it.
Hi Max,
Hard to say for certain on something like this, but it may well be a BC808-40 type PNP transistor.
We no longer keep in-house stock of the BC808-40, but we list them here.
Assuming that it is, in fact, a BC808-40, then you could use the BC807-40 in it’s place, as it has essentially the same specs, with the exception of that it can handle higher voltages without being damaged.
Thanks,
I’ll buy a few pcs and I will try it. I’ll keep you updated.
