Some part numbers from Infineon Technologies have a 5 digit suffix they refer to as the OPN (Orderable part Number) suffix.
These suffixes can be broken down into 3 sections.
1st Digit
Hal free, RoHS compliant & Totally lead free status of the part. Here are the options.
2nd & 3rd Digit
Packaging type, Moisture Protection Packaging and Packing size
4th & 5th Digit - Infineon Designator
The designator increments (e.g. from A1 to A2) whenever a new SP number is set up that does
not differ from a previous product in either Salesname or the first three OPN suffix identifiers.
Product variants such as different temperature ranges or ROM codes can therefore be recognized
by the designator.
For the manufacturer documentation explaining the suffix digits 1 through 5 Click here to see the Infineon part numbering guide.
Example
Using the charts when you look at part XMC1302T016X0032ABXUMA1
The suffix XUMA1 would call out the following
X = Halogen Free - RoHS Compliant - Totally Lead Free
UM = 330mm Tape & Reel
A1 = A1 Infineon Designator
Here are some part number examples with the common OPN suffixes.
XUMA1
XMC1302T016X0032ABXUMA1 XMC1302T038X0032ABXUMA1 XMC1302T038X0200ABXUMA1 XE167FM72F80LRABKXUMA1 XMC1201T038F0200ABXUMA1 C161SL25MAAFXUMA1 XE167F96F80LACFXUMA1 XE164FM72F80LRABKXUMA1 C505CA4EMCAKXUMA1 XMC1301T016F0032ABXUMA1 XMC1302Q024X0064ABXUMA1 XMC1202T028X0064ABXUMA1 XMC1201Q040F0200ABXUMA1 XC886CM8FFA5VACKXUMA1 XMC1100T016X0016ABXUMA1 XMC1202T016X0032ABXUMA1 XMC1100T016F0064ABXUMA1 XMC1202Q040X0032ABXUMA1 XMC1100Q024F0064ABXUMA1 XMC1100T016X0064ABXUMA1 XMC1302Q024F0064ABXUMA1 XMC1100T038X0064ABXUMA1 XMC1302Q040X0200ABXUMA1 XMC1402T038X0200AAXUMA1 XMC1402T038X0200AAXUMA1 XMC1402T038X0200AAXUMA1 XMC4108Q48K64BAXUMA1 XMC1402F064X0200AAXUMA1 XMC1404Q048X0200AAXUMA1 XMC1404Q064X0200AAXUMA1 XMC4200Q48K256ABXUMA1 XMC4200Q48K256BAXUMA1 XMC4100Q48K128ABXUMA1 XMC4100Q48K128BAXUMA1 C161PILMCABXUMA1 XC161CJ16F40FBBFXUMA1 XC161CJ16F40FBBKXUMA1 C164CI8EMCBFXUMA1 TC275T64F200WCAKXUMA1 TC277T64F200SCAKXUMA1 C167CRLMHABXQLA1 TC275TP64F200WCAKXUMA1 TC277TP64F200SCAKXUMA1 TC1762128F80HLACKXUMA1 XMC1202T028X0032AAXUMA1 XMC1202T028X0032ABXUMA1 XC8664FRIBEFXUMA1 XC886CM8FFI5VACFXUMA1 TC233LP32F200FACKXUMA1 TC233LP32F200FABKXUMA1 TC233LP32F200NACKXUMA1 XMC1100T016F0008ABXUMA1 XMC1100Q024F0008ABXUMA1 XMC1100T016F0016ABXUMA1 XMC1301T016F0008ABXUMA1 XMC1100Q024F0016ABXUMA1 XMC1301Q024F0008ABXUMA1 XMC1301Q024F0016ABXUMA1 XMC1301T016F0016ABXUMA1 XMC1301T016X0008ABXUMA1 XMC1301T016X0008AAXUMA1 XMC1100Q040F0016ABXUMA1 XMC1301Q040F0008ABXUMA1 XMC1100T038F0016ABXUMA1 XMC1301T016X0016ABXUMA1 XMC1301T038F0008ABXUMA1 XMC1302T016X0008ABXUMA1 XC822T0FRIAAFXUMA1 XMC1302Q024F0016ABXUMA1 XMC1100T016F0032ABXUMA1 XMC1302T016X0008AAXUMA1 XMC1100Q024F0032ABXUMA1 XMC1301Q040F0016ABXUMA1 XMC1201T028F0016ABXUMA1 XMC1202T016X0016ABXUMA1 XMC1301T038F0016ABXUMA1 XMC1302T016X0016ABXUMA1 XMC1302Q024X0016ABXUMA1 XMC1100T016X0032ABXUMA1 XMC1202Q024X0016ABXUMA1 XMC1201Q040F0016ABXUMA1 XMC1201T038F0016ABXUMA1 XMC1202T028X0016ABXUMA1 XMC1100Q040F0032ABXUMA1 XMC1100T038F0032ABXUMA1 XMC1202Q040X0016ABXUMA1 XMC1302Q024F0032ABXUMA1 XMC1302Q040X0016ABXUMA1 XC8221FRIAAFXUMA1 XMC1301Q040F0032ABXUMA1 XMC1201T028F0032ABXUMA1 XMC1302T038X0016ABXUMA1 XMC1301T038F0032ABXUMA1 XMC1301T038X0032ABXUMA1 XMC1202Q024X0032ABXUMA1 XMC1302Q024X0032ABXUMA1 XC8362FRIABFXUMA1 XC822T1FRIAAFXUMA1 XMC1201Q040F0032ABXUMA1 XMC1201T038F0032ABXUMA1 XC8661FRAABKXUMA1 XMC1302Q040X0032ABXUMA1 XC8662FRIBEFXUMA1 XC822M1FRIAAFXUMA1 XC822MT1FRAAAKXUMA1 XMC1100Q040F0064ABXUMA1 XC8662FRABEFXUMA1 XC822MT1FRIAAFXUMA1 XMC1100T038F0064ABXUMA1 XMC1402Q040X0032AAXUMA1 XC836T2FRIABFXUMA1 XMC1402T038X0032AAXUMA1 XMC1301T038F0064ABXUMA1 XMC1202T016X0064ABXUMA1 XMC1201Q040F0064ABXUMA1 XMC1402Q048X0032AAXUMA1 XMC1201T038F0064ABXUMA1 XMC1302Q040X0064ABXUMA1 XC836M1FRIABFXUMA1 XC8662FRABEKXUMA1 XC836MT2FRIABFXUMA1 XC836M2FRIABFXUMA1 XMC1302T038X0064ABXUMA1 XC8662FRIBEKXUMA1 XC8662FRA5VBEAXUMA1 XMC1403Q040X0064AAXUMA1 XMC1402Q040X0064AAXUMA1 XMC1401Q048F0064AAXUMA1 XC8664FRABEFXUMA1 XMC1402T038X0064AAXUMA1 XC836MT2FRAABKXUMA1 XC8664FRABEKXUMA1 XMC1402Q048X0064AAXUMA1 XMC1403Q048X0064AAXUMA1 XC866L1FRAABKXUMA1 XC8664FRIBEKXUMA1 XMC1402Q064X0064AAXUMA1 XMC1201Q040F0128ABXUMA1 XMC1401F064F0064AAXUMA1 XMC1403Q064X0064AAXUMA1 XMC1201T038F0128ABXUMA1 XMC1302Q040X0128ABXUMA1 XC866L4FRABEKXUMA1 XC866L4FRA3VBEKXUMA1 XMC1404Q048X0064AAXUMA1 XMC1302T038X0128ABXUMA1 XMC1201T038F0128AAXUMA1 XMC1402F064X0064AAXUMA1 SAA-XC866-4FRA 5V BE XC8868FFI5VACFXUMA1 XC8886FFI5VACFXUMA1 XC8866FFI5VACFXUMA1 XC8866FFA5VACKXUMA1 XMC1302T038X0128AAXUMA1 XMC1404Q064X0064AAXUMA1 XMC1403Q040X0128AAXUMA1 XMC1402Q040X0128AAXUMA1 XMC1401Q048F0128AAXUMA1 XC866L4FRIBEKXUMA1 XMC1402T038X0128AAXUMA1 XMC1404F064X0064AAXUMA1 XC866L2FRA3VBELXUMA1 XC866L2FRA5VBELXUMA1 XC8888FFI5VACFXUMA1 XMC1402Q048X0128AAXUMA1 XMC1403Q048X0128AAXUMA1 XC886C6FFA5VACFXUMA1 XMC1401F064F0128AAXUMA1 XMC1402Q064X0128AAXUMA1 XMC1403Q064X0128AAXUMA1 XMC1404Q048X0128AAXUMA1 XC886LM6FFI5VACFXUMA1 XC886C6FFI3V3ACFXUMA1 XC886C6FFI5VACFXUMA1 XC8664FRA3VBELXUMA1 XC8664FRA5VBELXUMA1 XMC1402F064X0128AAXUMA1 XMC1404Q064X0128AAXUMA1 XMC1200T038F0200ABXUMA1 XC886LM8FFI5VACFXUMA1 XC87813FFA5VACKXUMA1 XMC1404F064X0128AAXUMA1 XC886LM6FFA5VACKXUMA1 XMC1403Q040X0200AAXUMA1 XC866L4FRA3VBELXUMA1 XMC1402Q040X0200AAXUMA1 XC87816FFI5VACFXUMA1 XC87813FFA5VACFXUMA1 XC888LM6FFA5VACKXUMA1 XC886LM8FFA5VACKXUMA1 XC888C8FFA5VACKXUMA1 XC886C8FFA5VACKXUMA1 XMC1403Q048X0200AAXUMA1 XC886C8FFI5VACFXUMA1 XMC1402Q048X0200AAXUMA1 XE161FU8F40VAAKXUMA1 XMC1402Q064X0200AAXUMA1 XMC1403Q064X0200AAXUMA1 XC888LM8FFI5VACFXUMA1 XC87816FFA5VACKXUMA1 TLS715B0EJV50XUMA1 TLS805B1SJVXUMA1 TLE4254GAXUMA1 TLE4263-2ES TLE4267GM TLE7272-2E TLE4263GMXUMA1 TLE4262GMXUMA1 IFX1763XEJV50XUMA1 TLS805B1LDVXUMA1 TLS820D0ELV33XUMA1 TLE4254EJAXUMA1 TLE42694GMXUMA2 TLE46782LDXUMA1 TLF42772LDXUMA1 TLE42794GMXUMA2 TLE46782ELXUMA1 TLE42994EXUMA1 TLE72732GV33XUMA1 TLE42994GMXUMA1 TLE4269GMXUMA1 TLE4268GSXUMA1
HTSA1 and HTSA2
IFX25001ME V33 IFX20001MBV33HTSA1 IFX20002MBV33HTSA1 IFX20001MBV50HTSA1 TLE42502GHTSA1 TLE4285GHTSA1 TLE42962GV50HTSA1 TLE4294GV50HTSA1 IFX54211MBV33HTSA1 IFX20002MBV50HTSA1 TLE4250GHTSA1 IFX21401MB IFX25001ME V25 TLS202A1MBVHTSA1 TLE42344GHTSA1 TLE4296GV50HTSA1 TLE4295G V50 TLE42962GV33HTSA1 TLE4274GS V25 TLE4286GHTSA1 TLE4295GV26HTSA1 TLE4295GV30HTSA1 TLE4295GV33HTSA1 TLE4296GV30HTSA1 TLE4296GV33HTSA1
TLE42642GHTSA2 TLE42642GHTSA2 TLE42642GHTSA2 TLE42644G
ATMA1
BSZ340N08NS3 G BSC120N03MSGATMA1 BSC340N08NS3GATMA1 BSC093N04LSGATMA1 BSZ097N04LS G BSC054N04NSGATMA1 BSZ440N10NS3 G BSZ110N06NS3 G BSC050NE2LSATMA1 BSC050N03LS G BSC100N06LS3GATMA1 BSC052N03LSATMA1 BSC050N04LSGATMA1 BSC110N06NS3GATMA1 BSZ100N06LS3 G BSZ086P03NS3 G BSZ086P03NS3E G IPD50P04P4L11ATMA1 BSC123N08NS3GATMA1 BSC076N06NS3GATMA1 BSZ040N04LSGATMA1 BSC030N04NSGATMA1 BSC035N04LSGATMA1 BSC0902NSIATMA1 BSC160N10NS3GATMA1 BSC067N06LS3GATMA1 BSZ067N06LS3 G BSZ123N08NS3 G BSC025N03LSGATMA1 IPD122N10N3GATMA1 BSZ520N15NS3 G IPD30N08S2L21ATMA1 BSC109N10NS3GATMA1 BSC027N04LSGATMA1 SPD04N50C3ATMA1 BSC190N12NS3GATMA1 IPD90P04P405ATMA1 IPD90P04P4L04ATMA1 BSC011N03LSATMA1 BSZ018NE2LS BSC070N10NS5ATMA1 BSC900N20NS3 G BSC070N10NS3GATMA1 BSC016N03MSGATMA1 IPD60R450E6ATMA1 BSC010NE2LSATMA1 IPD034N06N3 G BSC057N08NS3GATMA1 BSC500N20NS3GATMA1 SPD06N80C3ATMA1 IPD90P03P4L04ATMA1 BSC123N10LSGATMA1 IPB054N08N3 G BSC010NE2LSIATMA1 BSC031N06NS3GATMA1 IPD110N12N3GATMA1 BSC040N08NS5ATMA1 BSC016N04LS G BSC028N06NSATMA1 IPD053N08N3GATMA1 BSC060N10NS3GATMA1 BSC040N10NS5ATMA1 IPD031N06L3 G BSC047N08NS3GATMA1 BSC010N04LSATMA1 IPD600N25N3GATMA1 BSC077N12NS3GATMA1 BSC190N15NS3GATMA1 IPD320N20N3GATMA1 BSC010N04LSIATMA1 IPB200N15N3 G IPB039N10N3 G IPB320N20N3 G BSC046N10NS3GATMA1 IPB009N03L G
HTMA1 and HTMA2
BAT6404E6433HTMA1 BAS7004E6433HTMA1 BAS7005E6433HTMA1 BAS7006E6433HTMA1 BAS4004E6433HTMA1 BAS4005E6433HTMA1 BAS4006E6433HTMA1 BAS7007E6433HTMA1 BAT240AE6433HTMA1
NTMA1
TLE4274DV50NTMA1 TLE4299GMNTMA1 TLE4270GNTMA1 TLE4299GNTMA1 TLE4270DNTMA1 TLE7270GNTMA1 TLE4251DNTMA1 TLE4275GNTMA1 TLE4251GNTMA1 TLE4252DNTMA1 TLE4262GNTMA1 TLE42662GNTMA1 TLE4274D V33 TLE4284DV50NTMA1 TLE4470G TLE4476D TLE7270DNTMA1 TLE7274DNTMA1 TLE4274GV85NTMA1 TLE4276GV10NTMA1 TLE4284DV26NTMA1 TLE4275DNTMA1 TLE4284DV15NTMA1 TLE4284DV33NTMA1 TLE4284DV18NTMA1 TLE4268GSNTMA1 TLE4269GNTMA1 TLE4279GNTMA1
AKSA1
IPP023NE7N3 G IPP120N20NFDAKSA1 IPP110N20NA IPP45P03P4L11AKSA1 IPP80P03P4L04AKSA1 IPP120P04P4L03AKSA1 IPP50N10S3L16AKSA1 IPP60R250CPXKSA1 IPP60R199CPXKSA1 IPP220N25NFDAKSA1 IPP60R299CPXKSA1 IPP030N10N5AKSA1 IPP65R110CFDAAKSA1 IPP17N25S3100AKSA1 IPP80N03S4L-03 IPP040N06NAKSA1 IPP80N08S2L07AKSA1 IPI029N06NAKSA1 IPI70N04S406AKSA1 IPI80N04S403AKSA1 IPP083N10N5AKSA1 IPI90N04S402AKSA1 IPP052N08N5AKSA1 IPI032N06N3GAKSA1 IPP029N06NAKSA1 IPP020N06NAKSA1 IPP023N10N5AKSA1 IPP060N06NAKSA1 IPI020N06NAKSA1 IPP020N08N5AKSA1 IPP80P04P4L08AKSA1 IPP80P04P407AKSA1 IPP80P04P4L06AKSA1 IPI45N06S4L08AKSA1 IPP80N04S404AKSA1 IPP80N04S4L04AKSA1 IPP80P03P4L07AKSA1 IPI80P04P4L08AKSA1 IPI80N04S404AKSA1 IPI80N04S4L04AKSA1 IPI70P04P409AKSA1 IPI80P04P407AKSA1 IPI80P04P4L06AKSA1 IPP70N04S406AKSA1 IPI80P03P4L07AKSA1 IPP80N04S403AKSA1 IPP80P04P4L04AKSA1 IPP100N04S4H2AKSA1 IPI80N03S4L03AKSA1 IPI80N06S405AKSA1
