Info about weight for part
I need the weight of this part. Could someone help me with this?
127712 Wakefield Thermal Solutions Heat Sinks
AH50600V05000FE Ohmite
Thank you.
Hello quan.nguyenanh29
I was unable to locate the weight for Wakefield Thermal Solutions part number 127712, DigiKey part number 345-127712-ND on the datasheet, Thermal Extrusions Selection Guideline or the manufacturers website.
The weight of Ohmite part number AH50600V05000FE, DigiKey part number AH50600V05000FE-ND is listed on the datasheet as 0.95 lbs.
DigiKey is unable to provide part specific details of stock prior to shipment. If there are any special requirements for your order, please include them into the order notes and DigiKey will attempt to accommodate.
Okay thank you!
