Inquiry Regarding HS Code and Availability in Korea
------Question for NPORT 6150-G2 Please Put your question below------
I would like to inquire about the following regarding the product.
1. HS Code Verification and Invoice Revision
As this product is intended for use as a component of semiconductor manufacturing equipment, could you please confirm whether HS Code 8486.90-2010 is applicable?
If applicable, please also confirm whether you can issue a revised invoice reflecting this HS Code and the corresponding product description.
2. Product Availability in Korea
We understand that this product is manufactured in the United States.
Could you please confirm whether it is available for direct purchase in South Korea?
We would appreciate your confirmation on the above matters.
Thank you for your assistance.
Best regards,
Greetings,
The product listing in question ships from a third party, and is not available for sale through DigiKey outside the USA at this time.
Please see the Environmental & Export Classifications section of the product page for the assigned classification. This typically is determined by the nature of the part itself, and not subject to change based on a statement of intended use.
