Is switch EG4771-ND a momentary switch?
I need a compact momentary DPDT switch. The switch part number EG4771-ND appears to be what I need, but I cannot tell from the description if it’s a momentary switch.
Welcome to the DigiKey tech forum community.
Unfortunately EG4771-ND is not a momentary switch no.
We have many similar rocker switches that have momentary off or momentary on functions in DPDT configuration. Can you please clarify the exact switch function you need? For example the one you picked EG4771-ND is a on-off-on function.
You are able to filter by that parameter in our rocker switches category as shown in the pic below:
In the link below are all the DPDT momentary options that are panel mount snap in type:
DPDT Rocker Switches | Electronic Components Distributor DigiKey
Hope that helps.
That answered my question, thank you!
