When looking at part numbers for JAE’s FO-FC series optical adaptors, you may find a “-R” suffix at the end of the part number. Parts that ends with –R calls out the most basic/common part.
Since some parts in this series have other variants for slightly different mounting options, so part numbers with the -R suffix calls out a standard part number.
For example, FO-FC-RS-A1-R
Applicable Part Numbers
| DK Part # | Mfr Part # |
| 670-1869-ND | FO-FC-FS(FC-A3)-PBS-R |
| 670-1872-ND | FO-FC-FS(SC)-PBS-R |
| 670-1874-ND | FO-FC-FS(ST)-STD-PBS-R |
| 670-1873-ND | FO-FC-FS(SC)-STD-R |
| 670-1727-ND | FO-FC-FS(ST)-STD-R |
| 670-1870-ND | FO-FC-FS(FC-A3)-STD-R |
| 670-1867-ND | FO-FC-FS(DIA)-STD-PBS-R |
| 670-1868-ND | FO-FC-FS(DIA)-STD-R |
| FO-FC-FS(DIN)-STD-PBS-R-ND | FO-FC-FS(DIN)-STD-PBS-R |
| FO-FC-FS(DIN)-STD-R-ND | FO-FC-FS(DIN)-STD-R |
| FO-FC-FS(DIN-A1)-STD-R-ND | FO-FC-FS(DIN-A1)-STD-R |
| 670-2090-ND | FO-FC-RS-A1-R |
| 670-1225-ND | FO-FC-RS-A-R |
| 670-1224-ND | FO-FC-RS-A2-R |
