Kemet T368C156M050AS Cross Reference
DigiKey Part # 478-TAP156K050CCS-ND 399-T368C156M050AS-ND
Manufacturer Product # TAP156K050CCS T368C156M050AS
Mfr KYOCERA AVX KEMET
Series TAP T368
Capacitance 15 µF 15 µF
Tolerance ±10% ±20%
Voltage - Rated 50 V 50 V
ESR (Equivalent Series Resistance) 1.2Ohm –
Operating Temperature -55°C ~ 125°C -55°C ~ 85°C
Lifetime @ Temp. 1000 Hrs @ 85°C –
Mounting Type Through Hole Through Hole
Package/Case Radial Radial
Size / Dimension 0.335" Dia (8.50mm) 10.16mm x 6.35mm
Height - Seated (Max) 0.551" (14.00mm) 10.67mm
Lead Spacing 0.197" (5.00mm) 6.35mm
Manufacturer Size Code K C
Datasheet Click Here Click Here
Please review the datasheets to ensure the alternative will work for your application.
