The CM5441Z161B-10 Common Mode Choke from Laird is rated for current up to 75 Amps for power line applications.
During the soldering process, the manufacturer suggests that this component should be adequately pre-heated before soldering, as illustrated below.
Applicable part numbers
240-2488-ND
