Choosing the right LED package is a critical step in any lighting or display design. LED packaging not only affects brightness and thermal performance, but also impacts manufacturability, reliability, and overall system cost. This guide provides a clear overview of common LED packaging technologies and how to select the right option for your application.
Common LED Packaging Types
Through-hole LEDs use leads that pass through the PCB, offering strong mechanical stability. They are easy to inspect and replace, making them suitable for industrial or rugged environments. However, they are less ideal for compact designs or high-volume automated assembly.
Best for:
Rugged applications, legacy designs, low-density boards
Surface-Mount (SMT) & PLCC LEDs
SMT and PLCC packages are widely used due to their small footprint and compatibility with automated manufacturing. Available in standard sizes and multiple configurations, these packages offer good thermal performance, consistent color control, and flexible design options.
Best for:
High-volume production, compact PCBs, applications requiring consistent color and brightness
COB technology mounts multiple LED chips directly onto a substrate, creating a high-density light source with uniform output. This design improves light uniformity and simplifies assembly for high-output lighting solutions.
Best for:
High-lumen lighting, light strips, architectural and industrial illumination
How to Choose the Right LED Package
When selecting an LED package, consider these key factors:
Thermal Performance: High-power applications require packages with efficient heat dissipation.
Assembly Method: SMT and PLCC support automated reflow processes, while through-hole offers mechanical strength.
Optical Requirements: Viewing angle, brightness uniformity, and color consistency vary by package type.
Application Environment: Automotive, industrial, or outdoor applications may require more robust packaging.
Conclusion
Understanding LED packaging technologies helps designers balance performance, reliability, and manufacturing efficiency. Whether your application requires compact SMT LEDs, high-output COB solutions, or rugged through-hole components, American Bright offers a wide range of LED packaging options to support diverse design needs.
