Kernel 5.11.10
I enabled ‘Export input device LEDs in sysfs’ (INPUT_LEDS) in my kernel .config because it has ‘INPUT’ and ‘LED’ in it’s name. However I’m not sure what the purpose of INPUT_LEDS. I have two guesses.
It is an LED that is associated with a GPIO button (KEYBOARD_GPIO) such as the NumLock key on a keyboard. When the NumLock key is pressed then the LED will toggle on/off.
If this is correct the why not just use:
leds {
pinctrl-names = "default";
pinctrl-0 = <&user_leds_s0>;
compatible = "gpio-leds";
led1 {
label = "board:green:led";
gpios = <&gpio1 23 GPIO_ACTIVE_LOW>;
linux,default-trigger = "numlock";
default-state = "off";
It is an LED that is being used as input device. Search for ‘Using Light Emitting Diode Arrays as
Touch-Sensitive Input and Output Devices’.
What is the intended purpose of the kernel config setting ‘INPUT_LEDS’?
Thank you,
