I am using TFTP to load kernel and device tree overlay to a beaglebone black. I am using NFS to load rootfs. Everything seems to go well until I try to use uarts. It seems that the device tree overlays for them did not get loaded. How do you install device tree overlays when using TFTP and NFS? Do I need to merge all my device tree overlays and set dtb to that file? Below is my uEnv.txt file.
##Rename as: uEnv.txt to boot via nfs
##https://www.kernel.org/doc/Documentation/filesystems/nfs/nfsroot.txt
##SERVER: sudo apt-get install tftpd-hpa
##SERVER:
##SERVER: zImage boot:
##SERVER: TFTP_DIRECTORY defined in /etc/default/tftpd-hpa
##SERVER: zImage/*.dtb need to be located here:
##SERVER: TFTP_DIRECTORY/zImage
##SERVER: TFTP_DIRECTORY/dtbs/*.dtb
##SERVER:
##SERVER: uname_r boot:
##SERVER: Change TFTP_DIRECTORY to /NFSEXPORT/boot
##SERVER: TFTP_DIRECTORY/vmlinuz-${uname_r}
##SERVER: TFTP_DIRECTORY/dtbs/${uname_r}/*.dtb
##client_ip needs to be set for u-boot to try booting via nfs
client_ip=192.168.1.151
#u-boot defaults: uncomment and override where needed
server_ip=192.168.1.102
gw_ip=192.168.1.1
netmask=255.255.255.0
hostname=beaglebone
device=eth0
autoconf=off
#root=/dev/nfs
root_dir=/var/lib/beaglebone/pntr/debian-dev
nfs_options=,vers=3
nfsrootfstype=ext4 rootwait fixrtc
nfsroot=${server_ip}:${root_dir}${nfs_options}
##use uname_r= only if TFTP SERVER is setup for uname_r boot:
uname_r=4.19.37-bone32
#uuid=
#dtb=
###U-Boot Overlays###
###Documentation: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#U-Boot_Overlays
###Master Enable
enable_uboot_overlays=1
###Overide capes with eeprom
#uboot_overlay_addr0=/lib/firmware/<file0>.dtbo
#uboot_overlay_addr1=/lib/firmware/<file1>.dtbo
#uboot_overlay_addr2=/lib/firmware/BB-UART4-RTSCTS-00A0.dtbo
#uboot_overlay_addr3=/lib/firmware/BB-UART5-RTSCTS-00A0.dtbo
###Additional custom capes
uboot_overlay_addr4=/lib/firmware/BB-UART2-00A0.dtbo
uboot_overlay_addr5=/lib/firmware/BB-UART4-00A0.dtbo
uboot_overlay_addr6=/lib/firmware/BB-UART5-00A0.dtbo
#uboot_overlay_addr7=/lib/firmware/BBB-PRU-UART0-00A0.dtbo
###Custom Cape
#dtb_overlay=/lib/firmware/BBB-PRU-UART0-00A0.dtbo
###Disable auto loading of virtual capes (emmc/video/wireless/adc)
#disable_uboot_overlay_emmc=1
disable_uboot_overlay_video=1
disable_uboot_overlay_audio=1
#disable_uboot_overlay_wireless=1
#disable_uboot_overlay_adc=1
###PRUSS OPTIONS
###pru_rproc (4.4.x-ti kernel)
#uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-4-TI-00A0.dtbo
###pru_rproc (4.14.x-ti kernel)
#uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-14-TI-00A0.dtbo
###pru_rproc (4.19.x-ti kernel)
#uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-19-TI-00A0.dtbo
###pru_uio (4.4.x-ti, 4.14.x-ti, 4.19.x-ti & mainline/bone kernel)
uboot_overlay_pru=/lib/firmware/AM335X-PRU-UIO-4-19-00A0.dtbo
###Cape Universal Enable
enable_uboot_cape_universal=1
###Debug: disable uboot autoload of Cape
#disable_uboot_overlay_addr0=1
#disable_uboot_overlay_addr1=1
#disable_uboot_overlay_addr2=1
#disable_uboot_overlay_addr3=1
###U-Boot fdt tweaks... (60000 = 384KB)
#uboot_fdt_buffer=0x60000
cmdline=coherent_pool=1M net.ifnames=0 cape_universal=enable
#In the event of edid real failures, uncomment this next line:
#cmdline=coherent_pool=1M net.ifnames=0 quiet cape_universal=enable video=HDMI-A-1:1024x768@60e
#Use an overlayfs on top of a read-only root filesystem:
#cmdline=coherent_pool=1M net.ifnames=0 quiet cape_universal=enable overlayroot=tmpfs
##enable Generic eMMC Flasher:
##make sure, these tools are installed: dosfstools rsync
#cmdline=init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh
