Looking for a Active “LOW” Tri-state Buffer
I am looking for a Active “LOW” Tri-state Buffer similar to a TC7SZ125F but with the input enabled on LOW.
Can anybody suggest a part number?
Thank you!
I got it. 74LVC1G125GV seems to be doing what I need.
My question now becomes : what is the filter I need to use in DigiKey search to filter out the parts with this characteristic?
I believe most tri-state buffers are /OE which means output enabled on low.
There is no parametric search for this feature, this is checking datasheets for function tables to verify:
Thank you. that is what I did.
That brings another question. :slight_smile:
Why are there no parameters to search for this feature?
I think the reason is most buffers would have an active low output enable.
We believe in continuous improvement in a large part from feedback we receive from customers. If you think of something we could improve upon please feel free to hit the Feedback button located on the side of the page.
Because maintaining a parametric dataset for millions of parts is difficult and costly. Lines need to be drawn somewhere…
Also, discrete logic devices of the type are fairly well standardized. One might consult a list of device functions to identify an item of interest.
Thank you for the information. Very helpful.
