Looking for a thermistor replacement
Hi
I am trying to find an NTC thermistor replacement. The original is from a Polk Audio PSW1000 subwoofer.
The schematic description is:
SL154R00A 3W 15% KS0021
The package is a 25mm green disc marked DSP 056
I think it is a current-limiting thermistor
Any ideas?
Cheers
Al
Hello @al12,
Thank you for your post.
I found a few places online that mentioned the parameters, but I do not see that we carry that exact part number.
We do have one that is really close in multiple ratings.
I would suggest taking a look at our number 4316-5D2-18LC-ND.
Thanks, Brent!
I ordered one. It should work fine.
Cheers
Al
If that is true, then the part is more likely PTC.
PTC lowers current (higher R) with temperature rise, NTC raises current (lower R) with temperature rise.
It seems likely that the use case here is for inrush limiting, rather than overcurrent protection. In which case, the NTC action does indeed fit the bill.
Hey, I also happen to be fixing a PSW1000 as mine blew just a couple weeks ago! My DSP056 were also fired. Seems like I had some transistors short… TBD I suppose. Anyways, would you be able to send me a copy of the schematics? I reached out to Polk Audio and they agreed to send it but I’m still waiting on it. Thanks!
Jonjonmia,
Thank you for your inquiry.
Unfortunately we would not have the schematic for this one.
By the way, the “SL154R00A” mentioned in the initial inquiry looks quite similar to the following part number with the letter “A” replaced by the number “8”, which possibly not coincidentally happens to sound almost the same.
  • SL154R008 Inrush current limiter, 4Ω @ 25°C, 8A max steady-state current, 16mm disc
Regarding the markings on the green “DSP” part shown, I haven’t found a key to decode that number. It’s reasonably likely that the “05” represents “5Ω” (@ 25°C) and that “6” represents “6 amps” for maximum steady-state current, but I can not confirm.
Regardless, the 4316-5D2-18LC-ND mentioned above is probably a reasonable option, too.
