M8 Cable Assemblies
Does anyone make an M8 cable assemblies compatible with the TE Connectivity female connectors P/Ns T4041037041-000 and T4041037031-000?
Or would it be easier to find a female to female cable and use the TE Conn male connector T4040034041-000? I also need an M12 to M8 female to female cable assembly or an M12 to M8 Cable assembly that is compatible with T4041037041-000. Any help would be appreciated.
@francis.bechard
I am not seeing that we currently list a pre-made cable that would include the conversion you are looking for in both cables.
It may be something our custom team can assist with (custom.orders@digikey.com).
You are likely going to need to provide a drawing that shows how you would like the pin outs to be for both cables.
@francis.bechard
For mating connectors I found the below.
For the T4041037041-000
A few option were found that can work.
Plug, Male Pins Circular Connector Assemblies | Circular Connectors | Electronic Components Distributor DigiKey
For the T4041037031-000
T4011008031-000 was found
T4011008031-000 TE Connectivity AMP Connectors | Connectors, Interconnects | DigiKey
For the M12 cable connector I would need to know if it would be a 4 position connection to narrow options down further.
M12 options found otherwise.
