Machinechat with STM32F746 and X-NUCLEO-IKS01A3
Software
Project Parts
In Arduino, use this link in the " Additional Boards Managers URLs " field: to add STM32 support.
https://github.com/stm32duino/BoardManagerFiles/raw/master/STM32/package_stm_index.json
Add these libraries thru Arduino’s Library Manager:
Approve the install of these library dependencies:
Lab1
With the STM32H746 plugged into your PC thru the USB connector (CN1), let’s make sure we can program the board by using a simple Blink LED Demo, this code will blink LD1.
void setup() {
  // initialize digital pin LED_BUILTIN as an output
  pinMode(LED_BUILTIN, OUTPUT);
void loop() {
  digitalWrite(LED_BUILTIN, HIGH);
  delay(500);
  digitalWrite(LED_BUILTIN, LOW);
  delay(500);
Full Source:
Verify and Upload:
LD1 should be blinking.
Lab2
The STM32H746 has an onboard ethernet, which can be enabled thru the STM32Ethernet library. Initialize this library with Ethernet.begin()., then use Ethernet.localIP() to print our new IP address to the debug terminal. In this example we should get an IP address from our local DHCP server.
Add LwIP.h and STM32Ethernet.h header files:
#include <LwIP.h>
#include <STM32Ethernet.h>
Enable Serial Port for debugging:
  // Open serial communications and wait for port to open:
  Serial.begin(115200);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
Initialize Ethernet Library
  // give the ethernet module time to boot up:
  delay(1000);
  // start the Ethernet connection:
  Ethernet.begin();
  // print the Ethernet board/shield's IP address:
  Serial.print("My IP address: ");
  Serial.println(Ethernet.localIP());
Full Source
Verify and Upload, Arduino’s Serial Monitor should report an IP address:
My IP address: 192.168.3.229
Lab3
Next let’s verify we have an active link, with Ethernet.linkStatus(), the LED will only be on with an active connection. Test by removing the Ethernet Cable.
void loop() {
  if (Ethernet.linkStatus() == LinkON) {
    Serial.println("Link status: On");
  else if (Ethernet.linkStatus() == LinkOFF) {
    Serial.println("Link status: Off");
  delay(500);
Full Source
Verify and Upload, Arduino’s Serial Monitor should also report Link status, matching the LD1, unplug Ethernet Cable to verify.
Link status: On
Link status: On
Link status: Off
Link status: Off
Link status: On
Lab4
Add STTS751 Sensor
#include <STTS751Sensor.h>
STTS751Sensor *STTS751_Temp;
  // Initialize I2C bus.
  Wire.begin();
  // Initialize STTS751 Sensor
  STTS751_Temp = new STTS751Sensor (&Wire);
  STTS751_Temp->Enable();
void loop() {
  //Read STTS751 Temperature
  float STTS751_tempC = 0;
  STTS751_Temp->GetTemperature(&STTS751_tempC);
  float STTS751_tempF = (STTS751_tempC * 1.8) + 32.0F;
  Serial.print(" | Temp[F]: ");
  Serial.print(STTS751_tempF, 2);
  Serial.println(" |");
Full Source
Verify and Upload, Arduino’s Serial Monitor should now include Temperature data from the STTS751
 | Temp[F]: 74.30 |
Link status: On
 | Temp[F]: 74.30 |
Link status: On
Lab5
Add HTS221 Sensor
#include <HTS221Sensor.h>
HTS221Sensor *HTS221_HumTemp;
  // Initialize HTS221 Sensor
  HTS221_HumTemp = new HTS221Sensor (&Wire);
  HTS221_HumTemp->Enable();
  // Read HTS221 Humidity and Temperature
  float HTS221_humidity = 0, HTS221_tempC = 0;
  HTS221_HumTemp->GetHumidity(&HTS221_humidity);
  HTS221_HumTemp->GetTemperature(&HTS221_tempC);
  float HTS221_tempF = (HTS221_tempC * 1.8) + 32.0F;
  Serial.print(HTS221_tempF, 2);
  Serial.print("| Hum[%]: ");
  Serial.print(HTS221_humidity, 2);
Full Source
Verify and Upload, Arduino’s Serial Monitor should now include Temperature and Humidity data from the HTS221.
 | Temp[F]: 74.07 | Temp[F]: 72.32| Hum[%]: 41.20 |
Link status: On
 | Temp[F]: 74.19 | Temp[F]: 72.32| Hum[%]: 41.20 |
Link status: On
Lab6
Add LPS22HH Sensor
#include <LPS22HHSensor.h>
LPS22HHSensor *LPS22HH_PressTemp;
  // Initialize LPS22HH Sensor
  LPS22HH_PressTemp= new LPS22HHSensor(&Wire);
  LPS22HH_PressTemp->Enable();
  // Read LPS22HH Pressure and Temperature.
  float LPS22HH_pressure = 0, LPS22HH_tempC = 0;
  LPS22HH_PressTemp->GetPressure(&LPS22HH_pressure);
  LPS22HH_PressTemp->GetTemperature(&LPS22HH_tempC);
  float LPS22HH_tempF = (LPS22HH_tempC * 1.8) + 32.0F;
  Serial.print(LPS22HH_tempF , 2);
  Serial.print(" | Pres[hPa]: ");
  Serial.print(LPS22HH_pressure, 2);
Full Source
Verify and Upload, Arduino’s Serial Monitor should now include Temperature and Pressure data from the LPS22HH.
 | Temp[F]: 73.96 | Temp[F]: 72.14 | Temp[F]: 74.35| Hum[%]: 41.30 | Pres[hPa]: 979.12 |
Link status: On
 | Temp[F]: 73.96 | Temp[F]: 72.14 | Temp[F]: 74.35| Hum[%]: 41.30 | Pres[hPa]: 978.99 |
Link status: On
Lab7
Generate Json data object
#include <ArduinoJson.h>
// Create a unique ID for the data from each STM32 running this code
const char* jediID = "STM32F7_IKSO1A3";
void loop() {
  String postData;
  StaticJsonDocument <200> doc;
  JsonObject context = doc.createNestedObject("context");
  context["target_id"] = String(jediID);
  JsonObject data = doc.createNestedObject("data");
  data["HTS221_humidity"] = HTS221_humidity;
  data["HTS221_tempF"] = HTS221_tempF;
  data["LPS22HH_pressure"] = LPS22HH_pressure;
  data["LPS22HH_tempF"] = LPS22HH_tempF;
  data["STTS751_tempF"] = STTS751_tempF;
  serializeJson(doc, postData);
  //This prints the JSON to the serial monitor screen
  Serial.println(postData);
Full Source
Verify and Upload, Arduino’s Serial Monitor should now include the Json data object
{"context":{"target_id":"STM32F7_IKSO1A3"},"data":{"HTS221_humidity":41,"HTS221_tempF":72.14,"LPS22HH_pressure":978.8882,"LPS22HH_tempF":74.39,"STTS751_tempF":73.9625}}
Lab8
Transmit Json data object
#include <ArduinoHttpClient.h>
char serverAddress[] = "192.168.3.104";  // server address
int port = 8100;
// initialize the library instance:
EthernetClient eth;
HttpClient client = HttpClient(eth, serverAddress, port);
    String contentType = "application/json";
    client.post("/v1/data/mc", contentType, postData);
    // read the status code and body of the response
    int statusCode = client.responseStatusCode();
    String response = client.responseBody();
    Serial.print("Status code: ");
    Serial.println(statusCode);
    Serial.print("Response: ");
    Serial.println(response);
  delay(500);
Full Source
Verify and Upload, Arduino’s Serial Monitor should now report back a server response code:
Status code: 200
Response: "Data sent successfully"
