Does Maker-Uno work with the Arduino Web Editor?
Maker-Uno - Support - Engineering and Component Solution Forum - TechForum │ Digi-Key (digikey.com)
According to their documentation, it does.
From that documentation:
“It is Arduino UNO R3 compatible, and by that, Maker UNO can be programmed via Arduino IDE and compatible with all the example code and libraries for Arduino UNO.”
“Select “Arduino/Genuino UNO” for the “Board” in Arduino IDE and choose the correct COM port, you are ready to upload the code.”
