The Drawn-Seamless EMI/RFI Shield from Masach Tech has two optional shield configurations – Single one piece Shield or Two Piece configured by Cover and Frame. All have individual orderable part numbers.
For example, the MS168-10 model (Tin-Plated Steel), MS168-10S is referring to single one piece; MS168-10C and MS168-10F are referring to the Cover & Frame respectively of 2-piece configuration.
For the shield height, both options can referred to in the datasheet. For the above example of MS168-10, the height of a single one piece shield is 5.0mm. For the overall height of 2-piece configuration, MS168-10C’s Cover material thickness is 0.2mm, and MS168-10F’s Frame height is 5.0mm. Therefore, the combined 2-piece height should be 5.2mm.
Applicable part numbers
MS168-10C
MS110-10S
MS213-10C
MS223-10S
MS409-10C
MS409-10F
MS631-10C
MS544-10F
MS631-10F
MS384-10C
MS638-10F
MS108-10C
MS087-10F
MS087-10C
MS320-10C
MS320-10F
MS190-10C
MS256-10F
MS148-10F
MS190-10F
MS130-10F
MS256-10C
MS130-10C
MS220-30F
MS233-20F
MS226-10C
MS220-20F
MS230-10F
MS191-10C
MS191-10F
MS321-10F
MS268-10F
MS220-10C
MS193-20F
MS250-10F
MS302-10F
MS302-10C
MS263-10CP
MS263-10F
MS260-10CP
MS259-10F
MS378-20F
MS300-10F
MS338-10C
MS293-10F
MS355-10C
MS323-10C
MS263-20F
MS355-10F
MS415-20C
MS338-10F
MS257-10C
MS260-10F
MS323-30C
MS544-10C
MS513-10C
MS353-20F
MS415-20F
MS593-10C
MS593-10F
MS593-10S
MS513-10F
MS737-10S
MS483-10C
MS483-10F
MS321-10C
MS210-10F
MS168-10F
MS210-10C
MS168-10S
MS250-10C
MS312-10C
MS312-10F
MS638-10C
MS384-10F
MS585-10F
MS585-10C
MS108-10S
MS108-10F
MS148-10C
MS093-10C
MS087-10S
MS102-10C
MS102-10S
MS320-10S
MS102-10F
MS209-20C
MS209-10C
MS156-10C
MS256-10S
MS193-10S
MS193-10C
MS093-10F
MS193-10F
MS190-10S
MS148-10S
MS156-10F
MS183-10S
MS110-20C
MS183-10F
MS156-10S
MS093-10S
MS110-10C
MS220-30CP
MS220-40CP
MS209-10F
MS220-30C
MS209-10S
MS135-20S
MS233-20S
MS220-20C
MS220-30S
MS209-20F
MS110-20S
MS135-20F
MS220-40C
MS135-20C
MS110-20F
MS130-10S
MS233-20C
MS268-20C
MS213-10CP
MS230-10C
MS213-10S
MS230-10S
MS220-20S
MS223-10C
MS233-10C
MS268-10C
MS210-10S
MS329-10C
MS226-10F
MS206-10S
MS191-10S
MS268-10S
MS268-20S
MS268-20F
MS321-10S
MS220-40F
MS220-40S
MS206-10F
MS220-10CP
MS220-10F
MS206-10C
MS193-20C
MS220-10S
MS310-10C
MS223-10F
MS259-10C
MS193-20S
MS310-10S
MS333-10S
MS333-10F
MS302-10S
MS233-10S
MS263-10S
MS310-10F
MS333-10C
MS329-10S
MS270-10C
MS233-10F
MS263-20C
MS329-10F
MS308-10S
MS259-10S
MS378-20S
MS448-10C
MS448-20C
MS308-10C
MS308-10F
MS378-20C
MS260-10C
MS405-10F
MS353-20C
MS290-10C
MS423-10S
MS345-10S
MS128-10S
MS300-10S
MS353-10C
MS412-10S
MS300-10C
MS412-10F
MS412-10C
MS423-10F
MS423-10C
MS290-10S
MS405-10S
MS288-10F
MS288-10C
MS345-10CP
MS405-10C
MS400-10C
MS400-10F
MS288-10S
MS409-10S
MS400-10S
MS323-10CP
MS293-10C
MS378-10F
MS345-20C
MS345-20F
MS323-10S
MS345-20S
MS293-10S
MS378-10S
MS323-20C
MS263-20S
MS323-20S
MS323-20CP
MS323-20F
MS323-10F
MS448-20S
MS448-10S
MS375-10F
MS466-10S
MS378-10C
MS448-10F
MS473-10S
MS355-10S
MS257-10F
MS448-20F
MS375-10S
MS338-10S
MS257-10S
MS270-10S
MS453-10C
MS520-10C
MS270-10F
MS473-10F
MS466-10F
MS366-10S
MS382-10C
MS366-10F
MS477-10S
MS260-10S
MS366-10C
MS466-10C
MS477-10C
MS477-10F
MS382-10S
MS382-10F
MS415-10S
MS353-20S
MS353-10S
MS353-10F
MS415-10F
MS415-10C
MS293-20S
MS293-20F
MS375-10C
MS415-20S
MS402-10S
MS511-10C
MS402-10F
MS402-10C
MS453-10F
MS453-10S
MS473-10CP
MS410-10F
MS410-10S
MS410-10C
MS593-20C
MS312-10S
MS473-10C
MS511-10S
MS511-10F
MS434-10S
MS544-10S
MS544-20C
MS323-30S
MS434-10C
MS434-10F
MS593-20S
MS544-20CP
MS593-20F
MS631-10S
MS570-10C
MS520-10S
MS520-10F
MS513-10S
MS570-10S
MS570-10F
MS737-10F
MS511-20C
MS544-20S
MS511-20S
MS511-20F
MS544-20F
MS483-10S
MS548-10C
MS737-10C
MS384-10S
MS585-10S
MS595-10S
MS595-10F
MS595-10C
MS638-10S
MS548-10S
MS548-10F
MS323-30F
MS155-20F
MS155-20S
MS155-20C
MS183-10C
MS243-10S
MS182-10C
MS243-10C
MS230-20S
MS183-20S
MS192-10S
MS230-20F
MS192-10C
MS192-10F
MS243-10F
MS183-20F
MS183-20C
MS182-10F
MS230-20C
MS182-10S
MS110-10F
MS128-10C
MS209-20S
MS213-10F
MS226-10S
MS215-10S
MS215-10F
MS215-10C
MS326-10C
MS207-10C
MS263-10C
MS293-20C
MS250-10S
MS207-10S
MS266-10F
MS207-10F
MS266-10C
MS266-10S
MS385-10S
MS385-10C
MS385-10F
MS345-10F
MS128-10F
MS290-10F
MS374-10C
MS374-10S
MS374-10F
MS326-10F
MS326-10S
MS345-10C
MS323-30CP
MS381-10F
MS353-30S
MS353-30C
MS381-10S
MS353-30F
MS381-10C
MS501-10C
MS501-10F
MS501-10S
2333-MS168-10C-ND
2333-MS110-10S-ND
2333-MS213-10C-ND
2333-MS223-10S-ND
2333-MS409-10C-ND
2333-MS409-10F-ND
2333-MS631-10C-ND
2333-MS544-10F-ND
2333-MS631-10F-ND
2333-MS384-10C-ND
2333-MS638-10F-ND
2333-MS108-10C-ND
2333-MS087-10F-ND
2333-MS087-10C-ND
2333-MS320-10C-ND
2333-MS320-10F-ND
2333-MS190-10C-ND
2333-MS256-10F-ND
2333-MS148-10F-ND
2333-MS190-10F-ND
2333-MS130-10F-ND
2333-MS256-10C-ND
2333-MS130-10C-ND
2333-MS220-30F-ND
2333-MS233-20F-ND
2333-MS226-10C-ND
2333-MS220-20F-ND
2333-MS230-10F-ND
2333-MS191-10C-ND
2333-MS191-10F-ND
2333-MS321-10F-ND
2333-MS268-10F-ND
2333-MS220-10C-ND
2333-MS193-20F-ND
2333-MS250-10F-ND
2333-MS302-10F-ND
2333-MS302-10C-ND
2333-MS263-10CP-ND
2333-MS263-10F-ND
2333-MS260-10CP-ND
2333-MS259-10F-ND
2333-MS378-20F-ND
2333-MS300-10F-ND
2333-MS338-10C-ND
2333-MS293-10F-ND
2333-MS355-10C-ND
2333-MS323-10C-ND
2333-MS263-20F-ND
2333-MS355-10F-ND
2333-MS415-20C-ND
2333-MS338-10F-ND
2333-MS257-10C-ND
2333-MS260-10F-ND
2333-MS323-30C-ND
2333-MS544-10C-ND
2333-MS513-10C-ND
2333-MS353-20F-ND
2333-MS415-20F-ND
2333-MS593-10C-ND
2333-MS593-10F-ND
2333-MS593-10S-ND
2333-MS513-10F-ND
2333-MS737-10S-ND
2333-MS483-10C-ND
2333-MS483-10F-ND
2333-MS321-10C-ND
2333-MS210-10F-ND
2333-MS168-10F-ND
2333-MS210-10C-ND
2333-MS168-10S-ND
2333-MS250-10C-ND
2333-MS312-10C-ND
2333-MS312-10F-ND
2333-MS638-10C-ND
2333-MS384-10F-ND
2333-MS585-10F-ND
2333-MS585-10C-ND
2333-MS108-10S-ND
2333-MS108-10F-ND
2333-MS148-10C-ND
2333-MS093-10C-ND
2333-MS087-10S-ND
2333-MS102-10C-ND
2333-MS102-10S-ND
2333-MS320-10S-ND
2333-MS102-10F-ND
2333-MS209-20C-ND
2333-MS209-10C-ND
2333-MS156-10C-ND
2333-MS256-10S-ND
2333-MS193-10S-ND
2333-MS193-10C-ND
2333-MS093-10F-ND
2333-MS193-10F-ND
2333-MS190-10S-ND
2333-MS148-10S-ND
2333-MS156-10F-ND
2333-MS183-10S-ND
2333-MS110-20C-ND
2333-MS183-10F-ND
2333-MS156-10S-ND
2333-MS093-10S-ND
2333-MS110-10C-ND
2333-MS220-30CP-ND
2333-MS220-40CP-ND
2333-MS209-10F-ND
2333-MS220-30C-ND
2333-MS209-10S-ND
2333-MS135-20S-ND
2333-MS233-20S-ND
2333-MS220-20C-ND
2333-MS220-30S-ND
2333-MS209-20F-ND
2333-MS110-20S-ND
2333-MS135-20F-ND
2333-MS220-40C-ND
2333-MS135-20C-ND
2333-MS110-20F-ND
2333-MS130-10S-ND
2333-MS233-20C-ND
2333-MS268-20C-ND
2333-MS213-10CP-ND
2333-MS230-10C-ND
2333-MS213-10S-ND
2333-MS230-10S-ND
2333-MS220-20S-ND
2333-MS223-10C-ND
2333-MS233-10C-ND
2333-MS268-10C-ND
2333-MS210-10S-ND
2333-MS329-10C-ND
2333-MS226-10F-ND
2333-MS206-10S-ND
2333-MS191-10S-ND
2333-MS268-10S-ND
2333-MS268-20S-ND
2333-MS268-20F-ND
2333-MS321-10S-ND
2333-MS220-40F-ND
2333-MS220-40S-ND
2333-MS206-10F-ND
2333-MS220-10CP-ND
2333-MS220-10F-ND
2333-MS206-10C-ND
2333-MS193-20C-ND
2333-MS220-10S-ND
2333-MS310-10C-ND
2333-MS223-10F-ND
2333-MS259-10C-ND
2333-MS193-20S-ND
2333-MS310-10S-ND
2333-MS333-10S-ND
2333-MS333-10F-ND
2333-MS302-10S-ND
2333-MS233-10S-ND
2333-MS263-10S-ND
2333-MS310-10F-ND
2333-MS333-10C-ND
2333-MS329-10S-ND
2333-MS270-10C-ND
2333-MS233-10F-ND
2333-MS263-20C-ND
2333-MS329-10F-ND
2333-MS308-10S-ND
2333-MS259-10S-ND
2333-MS378-20S-ND
2333-MS448-10C-ND
2333-MS448-20C-ND
2333-MS308-10C-ND
2333-MS308-10F-ND
2333-MS378-20C-ND
2333-MS260-10C-ND
2333-MS405-10F-ND
2333-MS353-20C-ND
2333-MS290-10C-ND
2333-MS423-10S-ND
2333-MS345-10S-ND
2333-MS128-10S-ND
2333-MS300-10S-ND
2333-MS353-10C-ND
2333-MS412-10S-ND
2333-MS300-10C-ND
2333-MS412-10F-ND
2333-MS412-10C-ND
2333-MS423-10F-ND
2333-MS423-10C-ND
2333-MS290-10S-ND
2333-MS405-10S-ND
2333-MS288-10F-ND
2333-MS288-10C-ND
2333-MS345-10CP-ND
2333-MS405-10C-ND
2333-MS400-10C-ND
2333-MS400-10F-ND
2333-MS288-10S-ND
2333-MS409-10S-ND
2333-MS400-10S-ND
2333-MS323-10CP-ND
2333-MS293-10C-ND
2333-MS378-10F-ND
2333-MS345-20C-ND
2333-MS345-20F-ND
2333-MS323-10S-ND
2333-MS345-20S-ND
2333-MS293-10S-ND
2333-MS378-10S-ND
2333-MS323-20C-ND
2333-MS263-20S-ND
2333-MS323-20S-ND
2333-MS323-20CP-ND
2333-MS323-20F-ND
2333-MS323-10F-ND
2333-MS448-20S-ND
2333-MS448-10S-ND
2333-MS375-10F-ND
2333-MS466-10S-ND
2333-MS378-10C-ND
2333-MS448-10F-ND
2333-MS473-10S-ND
2333-MS355-10S-ND
2333-MS257-10F-ND
2333-MS448-20F-ND
2333-MS375-10S-ND
2333-MS338-10S-ND
2333-MS257-10S-ND
2333-MS270-10S-ND
2333-MS453-10C-ND
2333-MS520-10C-ND
2333-MS270-10F-ND
2333-MS473-10F-ND
2333-MS466-10F-ND
2333-MS366-10S-ND
2333-MS382-10C-ND
2333-MS366-10F-ND
2333-MS477-10S-ND
2333-MS260-10S-ND
2333-MS366-10C-ND
2333-MS466-10C-ND
2333-MS477-10C-ND
2333-MS477-10F-ND
2333-MS382-10S-ND
2333-MS382-10F-ND
2333-MS415-10S-ND
2333-MS353-20S-ND
2333-MS353-10S-ND
2333-MS353-10F-ND
2333-MS415-10F-ND
2333-MS415-10C-ND
2333-MS293-20S-ND
2333-MS293-20F-ND
2333-MS375-10C-ND
2333-MS415-20S-ND
2333-MS402-10S-ND
2333-MS511-10C-ND
2333-MS402-10F-ND
2333-MS402-10C-ND
2333-MS453-10F-ND
2333-MS453-10S-ND
2333-MS473-10CP-ND
2333-MS410-10F-ND
2333-MS410-10S-ND
2333-MS410-10C-ND
2333-MS593-20C-ND
2333-MS312-10S-ND
2333-MS473-10C-ND
2333-MS511-10S-ND
2333-MS511-10F-ND
2333-MS434-10S-ND
2333-MS544-10S-ND
2333-MS544-20C-ND
2333-MS323-30S-ND
2333-MS434-10C-ND
2333-MS434-10F-ND
2333-MS593-20S-ND
2333-MS544-20CP-ND
2333-MS593-20F-ND
2333-MS631-10S-ND
2333-MS570-10C-ND
2333-MS520-10S-ND
2333-MS520-10F-ND
2333-MS513-10S-ND
2333-MS570-10S-ND
2333-MS570-10F-ND
2333-MS737-10F-ND
2333-MS511-20C-ND
2333-MS544-20S-ND
2333-MS511-20S-ND
2333-MS511-20F-ND
2333-MS544-20F-ND
2333-MS483-10S-ND
2333-MS548-10C-ND
2333-MS737-10C-ND
2333-MS384-10S-ND
2333-MS585-10S-ND
2333-MS595-10S-ND
2333-MS595-10F-ND
2333-MS595-10C-ND
2333-MS638-10S-ND
2333-MS548-10S-ND
2333-MS548-10F-ND
2333-MS323-30F-ND
2333-MS155-20F-ND
2333-MS155-20S-ND
2333-MS155-20C-ND
2333-MS183-10C-ND
2333-MS243-10S-ND
2333-MS182-10C-ND
2333-MS243-10C-ND
2333-MS230-20S-ND
2333-MS183-20S-ND
2333-MS192-10S-ND
2333-MS230-20F-ND
2333-MS192-10C-ND
2333-MS192-10F-ND
2333-MS243-10F-ND
2333-MS183-20F-ND
2333-MS183-20C-ND
2333-MS182-10F-ND
2333-MS230-20C-ND
2333-MS182-10S-ND
2333-MS110-10F-ND
2333-MS128-10C-ND
2333-MS209-20S-ND
2333-MS213-10F-ND
2333-MS226-10S-ND
2333-MS215-10S-ND
2333-MS215-10F-ND
2333-MS215-10C-ND
2333-MS326-10C-ND
2333-MS207-10C-ND
2333-MS263-10C-ND
2333-MS293-20C-ND
2333-MS250-10S-ND
2333-MS207-10S-ND
2333-MS266-10F-ND
2333-MS207-10F-ND
2333-MS266-10C-ND
2333-MS266-10S-ND
2333-MS385-10S-ND
2333-MS385-10C-ND
2333-MS385-10F-ND
2333-MS345-10F-ND
2333-MS128-10F-ND
2333-MS290-10F-ND
2333-MS374-10C-ND
2333-MS374-10S-ND
2333-MS374-10F-ND
2333-MS326-10F-ND
2333-MS326-10S-ND
2333-MS345-10C-ND
2333-MS323-30CP-ND
2333-MS381-10F-ND
2333-MS353-30S-ND
2333-MS353-30C-ND
2333-MS381-10S-ND
2333-MS353-30F-ND
2333-MS381-10C-ND
2333-MS501-10C-ND
2333-MS501-10F-ND
2333-MS501-10S-ND
