------Question for MHO5104 Please Put your question below------
What accessories are included with the MHO5104 SKU?
Which model logic probes and signal generator are compatible?
Welcome to the TechForum cls! According to the datasheet it should come with a power cord, USB cable, and passive probes (see Standard Accessories on page 34).
As for logic probes, the datasheet suggests PLA3204. We do not have this item in our catalog at this time. The device does have some signal generation built in, see the datasheet under “Arbitrary Function Generator.” As for external ones, it does not list specific function generators, so you’d have to review the datasheet for limitations on frequency and voltage input for figuring out what is compatible. Manuals can be found on RIGOL’s site as well.
