Hallo,
ich suche für die Molex MicroBlade Steckerbinder vorgecrimpte Brückendrähte. Direkt sind diese leider nicht zu finden bei Digikey.
Gibt es eventuell Brückendrähte von Molex aus einem anderen System die hier passen können?
Viele GRüße
Gregor
Hallo,
Viele GRüße
Gregor
Hello Walbeck, welcome to the forum!
The part you are asking about is currently obsolete, so once we sell out of the part, it will no longer be available. The following cable assemblies below have the same pitch as the connector you provided, but they do not look exactly the same.
Molex did suggest a replacement connector, however, it is not a drop-in replacement. The part number is WM24301-ND. I could not find any pre-made assemblies with this particular series in our catalog. However, we do have the necessary parts to potentially construct a cable assembly. You’d have to let us know if you just want wire leads or another connector on the other side. If you scroll down on the page for the connector, there are associated terminals to purchase. You’d have to select one of those based on the wire gauge you need. You would also have to find a wire in stock. Please visit this forum post for more information.
Let me know if you have further questions.
