Molex Crimp Connector Tool
------Question for 0192110001 Please Put your question below------
Hi,
What is the correct crimp tool to use with the Molex 0192110001 Wire Pin Connectors - DigiKey Part Number WM18376-ND?
Thank you!
Gary Didio
Hi,
Thank you for choosing Digikey. The recommended Hand crimper for 0192110001 wire pin terminal is WM9974-ND
Thank you! Anything less expensive? I only have about 100 connections to make.
Hello g.didio,
There are 2 other crimpers listed for that contact, that are less expensive.
They are WM18730-ND, and WM9987-ND.
