The difference between MNS2-9-IN-TS-ST and MNS2-9-IN-TS-ST-L03-PA from Monnit Corporation may not be apparent at first glance.
Confirmed by Monnit Corporation, they both are the same Industrial Wireless Temperature Sensors. The main difference is the lead length and antenna.
L03 = 3ft lead length with the probe. Other lead length options are available such as L10, L25, L50, L100
PA = Puck Antenna.
MNS2-9-IN-TS-ST is the standard version with a Di-pole SMA Antenna but MNS2-9-IN-TS-ST-L03-PA is the version of the Puck Antenna and 3ft lead with the probe.
Di-pole SMA Antenna:
Puck Antenna:
More information about the antennas:
Applicable Part Numbers
1859-1007-ND
1859-1004-ND
1859-1098-ND
MNS2-9-IN-TS-ST-L03
MNS2-9-IN-TS-ST
