IF I USE MORNSUN PV40-29B24 CAN I GET VARIABLE OUTPUT VOLTAGE ACCORDING TO CHANGE IN INPUT VOLTAGE? SUPPOSE IF I GIVE 1500 VDC AS INPUT I AM GETTING 24 VDC ,NOW IF I GIVE 1200 VDC DOES IT GIVE LESS THAN 24 VDC?
Hello SURESH, Welcome to the DigiKey TechForum.
The output of this converter is not adjustable. If you use an input voltage between 200-1500V, the output will be the same at 24VDC.
