This article is part of a guided learning series to explore real-world applications of MOSFETS and microcontrollers.
Canonical Article: How to Interface a Microcontroller with a Relay Using a MOSFET
Learning Companion (Q&A): Explore All Questions
You are reading: Question 5
What causes the dip in the relay’s current curve upon activation?
This post also answers these closely related questions:
- How can we visualize changes in magnetic reluctance?
- How do magnetic flux lines behave in a relay?
Clarification
Figure 1 show the waveforms for an activating relay. The 24 VDC input voltage (orange) is shown along with the corresponding coil current (blue). The waveform distortion is caused by a change in the magnetic reluctance as the armature moves into position.
Figure 1: Turn on command (orange) and the resulting relay current waveform (blue).
Answer
We expect a smooth 1st order response in current as the relay is activated. Instead, we see a dip in the current waveform near the 6 ms mark. This distortion is caused by the system’s changing magnetic properties.
This change in magnetic reluctance is best viewed as a series of steps with supporting illustration as Figure 2.
The coil is initially relaxed (no magnetic field) and the armature is relaxed in the normally open position.
A current is applied to the coil.
The coil’s magnetic field increases like a first-order system, based in the RL properties of the coil, yoke, and surrounding electrical circuit.
When the magnetic field increases, the armature is pulled to the coil thus changing the magnetic properties (inductance) of the coil.
The current is disturbed by the changing RL properties.
Technically, we say that the reluctance of the coil has changed. Originally, the relay’s coil had a large air gap. With the armature pulled in, the air gap (magnetic reluctance) is eliminated.
Figure 2: Picture showing the magnetic path for an initially energized but still open relay alongside an energized and closed relay.
Article by Aaron Dahlen, LCDR USCG (Ret.), Application Engineer at DigiKey
