Looking for mounting options for your EvoSignal® lighting. There are several mounts and adapters for each size. For you’re convenience each list below is separated by size. Please select mini, midi, or maxi size based on the light you are trying to mount.
Mini Series
| MFR PART # | 26070001 |
| DIGI-KEY PART # | 2582-26070001-ND |
| MANUFACTURER | WERMA USA Inc. |
| DESCRIPTION | Stack Light Mounting Base - - - - - |
| MFR PART # | 26070003 |
| DIGI-KEY PART # | 2582-26070003-ND |
| DESCRIPTION | Stack Light Mounting Adapter - - - - - |
| MFR PART # | 26070004 |
| DIGI-KEY PART # | 2582-26070004-ND |
| MFR PART # | 26070005 |
| DIGI-KEY PART # | 2582-26070005-ND |
| DESCRIPTION | Stack Light Mounting Tube - - - - - |
| MFR PART # | 26070006 |
| DIGI-KEY PART # | 2582-26070006-ND |
| DESCRIPTION | Stack Light Mounting Bracket - - - - - |
| MFR PART # | 26070007 |
| DIGI-KEY PART # | 2582-26070007-ND |
Midi Series
| MFR PART # | 26170001 |
| DIGI-KEY PART # | 2582-26170001-ND |
| MFR PART # | 26170002 |
| DIGI-KEY PART # | 2582-26170002-ND |
| DESCRIPTION | Stack Light Cable Gland - - - - - |
| MFR PART # | 26170003 |
| DIGI-KEY PART # | 2582-26170003-ND |
| MFR PART # | 26170005 |
| DIGI-KEY PART # | 2582-26170005-ND |
| MFR PART # | 26170006 |
| DIGI-KEY PART # | 2582-26170006-ND |
| MFR PART # | 26170007 |
| DIGI-KEY PART # | 2582-26170007-ND |
Maxi Series
| MFR PART # | 26270001 |
| DIGI-KEY PART # | 2582-26270001-ND |
| MFR PART # | 26270002 |
| DIGI-KEY PART # | 2582-26270002-ND |
| MFR PART # | 26270006 |
| DIGI-KEY PART # | 2582-26270006-ND |
| MFR PART # | 26270007 |
| DIGI-KEY PART # | 2582-26270007-ND |
EvoSignal® Optical Element Options
White
| Digi-Key Part Numbers | Manufacturer Part Numbers |
| 2582-26244060-ND | 26244060 |
| 2582-26142070-ND | 26142070 |
| 2582-46141060-ND | 46141060 |
| 2582-26041075-ND | 26041075 |
| 2582-46041075-ND | 46041075 |
| 2582-26242070-ND | 26242070 |
| 2582-26142060-ND | 26142060 |
| 2582-46041060-ND | 46041060 |
| 2582-46141070-ND | 46141070 |
| 2582-26244070-ND | 26244070 |
| 2582-26042075-ND | 26042075 |
| 2582-26144060-ND | 26144060 |
| 2582-46142070-ND | 46142070 |
| 2582-26041074-ND | 26041074 |
| 2582-26041060-ND | 26041060 |
| 2582-26042060-ND | 26042060 |
| 2582-26141070-ND | 26141070 |
| 2582-46042074-ND | 46042074 |
| 2582-26144070-ND | 26144070 |
| 2582-46142060-ND | 46142060 |
| 2582-26241060-ND | 26241060 |
| 2582-26042074-ND | 26042074 |
| 2582-26242060-ND | 26242060 |
| 2582-26241070-ND | 26241070 |
| 2582-46041074-ND | 46041074 |
| 2582-46042060-ND | 46042060 |
| 2582-26141060-ND | 26141060 |
| 2582-46042075-ND | 46042075 |
Red
| 2582-46012075-ND | 46012075 |
| 2582-26012060-ND | 26012060 |
| 2582-26011074-ND | 26011074 |
| 2582-26211060-ND | 26211060 |
| 2582-26011075-ND | 26011075 |
| 2582-46011060-ND | 46011060 |
| 2582-26214060-ND | 26214060 |
| 2582-26012074-ND | 26012074 |
| 2582-46011075-ND | 46011075 |
| 2582-46112060-ND | 46112060 |
| 2582-26114060-ND | 26114060 |
| 2582-26211070-ND | 26211070 |
| 2582-26114070-ND | 26114070 |
| 2582-46012074-ND | 46012074 |
| 2582-26212060-ND | 26212060 |
| 2582-46011074-ND | 46011074 |
| 2582-46012060-ND | 46012060 |
| 2582-26012075-ND | 26012075 |
| 2582-26112060-ND | 26112060 |
| 2582-46112070-ND | 46112070 |
| 2582-26212070-ND | 26212070 |
| 2582-26111060-ND | 26111060 |
| 2582-46111060-ND | 46111060 |
| 2582-26214070-ND | 26214070 |
| 2582-46111070-ND | 46111070 |
| 2582-26011060-ND | 26011060 |
| 2582-26111070-ND | 26111070 |
| 2582-26112070-ND | 26112070 |
Yellow
| 2582-26234060-ND | 26234060 |
| 2582-46131060-ND | 46131060 |
| 2582-26232060-ND | 26232060 |
| 2582-26032075-ND | 26032075 |
| 2582-26134070-ND | 26134070 |
| 2582-46031074-ND | 46031074 |
| 2582-26131070-ND | 26131070 |
| 2582-26032060-ND | 26032060 |
| 2582-26032074-ND | 26032074 |
| 2582-26031075-ND | 26031075 |
| 2582-46031075-ND | 46031075 |
| 2582-26131060-ND | 26131060 |
| 2582-26231070-ND | 26231070 |
| 2582-26132060-ND | 26132060 |
| 2582-46032060-ND | 46032060 |
| 2582-26134060-ND | 26134060 |
| 2582-26231060-ND | 26231060 |
| 2582-26132070-ND | 26132070 |
| 2582-46031060-ND | 46031060 |
| 2582-46132070-ND | 46132070 |
| 2582-26031074-ND | 26031074 |
| 2582-46131070-ND | 46131070 |
| 2582-46132060-ND | 46132060 |
| 2582-46032075-ND | 46032075 |
| 2582-46032074-ND | 46032074 |
| 2582-26232070-ND | 26232070 |
| 2582-26031060-ND | 26031060 |
| 2582-26234070-ND | 26234070 |
Green
| 2582-26021074-ND | 26021074 |
| 2582-26124060-ND | 26124060 |
| 2582-26022075-ND | 26022075 |
| 2582-26121060-ND | 26121060 |
| 2582-26222070-ND | 26222070 |
| 2582-46122070-ND | 46122070 |
| 2582-26224070-ND | 26224070 |
| 2582-46021060-ND | 46021060 |
| 2582-46022075-ND | 46022075 |
| 2582-46121060-ND | 46121060 |
| 2582-26221060-ND | 26221060 |
| 2582-26022074-ND | 26022074 |
| 2582-26122070-ND | 26122070 |
| 2582-46022074-ND | 46022074 |
| 2582-26121070-ND | 26121070 |
| 2582-26124070-ND | 26124070 |
| 2582-46022060-ND | 46022060 |
| 2582-26224060-ND | 26224060 |
| 2582-26021075-ND | 26021075 |
| 2582-46122060-ND | 46122060 |
| 2582-46021075-ND | 46021075 |
| 2582-26222060-ND | 26222060 |
| 2582-46121070-ND | 46121070 |
| 2582-26122060-ND | 26122060 |
| 2582-26221070-ND | 26221070 |
| 2582-26022060-ND | 26022060 |
| 2582-46021074-ND | 46021074 |
| 2582-26021060-ND | 26021060 |
Blue
| 2582-26254060-ND | 26254060 |
| 2582-26151070-ND | 26151070 |
| 2582-26051075-ND | 26051075 |
| 2582-26152060-ND | 26152060 |
| 2582-46151060-ND | 46151060 |
| 2582-26052075-ND | 26052075 |
| 2582-46052075-ND | 46052075 |
| 2582-46052074-ND | 46052074 |
| 2582-26051060-ND | 26051060 |
| 2582-26052074-ND | 26052074 |
| 2582-26052060-ND | 26052060 |
| 2582-26154060-ND | 26154060 |
| 2582-26152070-ND | 26152070 |
| 2582-46152060-ND | 46152060 |
| 2582-46051060-ND | 46051060 |
| 2582-46051075-ND | 46051075 |
| 2582-26051074-ND | 26051074 |
| 2582-46051074-ND | 46051074 |
| 2582-46152070-ND | 46152070 |
| 2582-26254070-ND | 26254070 |
| 2582-26151060-ND | 26151060 |
| 2582-46052060-ND | 46052060 |
| 2582-26154070-ND | 26154070 |
| 2582-26251070-ND | 26251070 |
| 2582-26251060-ND | 26251060 |
| 2582-26252060-ND | 26252060 |
| 2582-46151070-ND | 46151070 |
| 2582-26252070-ND | 26252070 |
Tri-Color
| 2582-26143060-ND | 26143060 |
| 2582-26043075-ND | 26043075 |
| 2582-26143070-ND | 26143070 |
