Non-ferrous D-Sub Connector
We are looking for a 25 pin d-sub male pin, solder cup connector with a backshell. Parts must be non ferrous. Prefered color for backshell or housing is white. Please advise what you have available. Thanks.
Thank you for your inquiry.
We do not stock it but 1731140122 is listed as Non-Magnetic.
I wasn’t able to track down a non-magnetic backshell but I suspect many plastic backshells with brass screws would fit the bill.
Hi @kdonovan,
One catch on the plastic hoods. Molex’s own size 3 hood 1731110021 has steel screws and a steel cable clamp on its drawing, and even the brass thumb screws they offer are nickel plated, so still magnetic. It’s the trap we run into most at Parter. I’d swap those for plain brass or nylon.
